help need suggestions ...timing belt on 1.5 broke ....
1.5 dx engine timing belt broke ...need some good idea's on what to do ....any replys are greatly accepted
Honda 4 LiFe
Honda 4 LiFe
What are you wanting to spend. There is a good chance that you have at least bent some valves. You can either replace the head or go ahead and do a swap.
that sucks!pull the head.take the rocker arm assembly off.turn the head over on fill the valve chamber with kerosene ,can use gas but?fill the chamber up to the top.if it holds kero then your fine,if not and leaks then you have a bent valve.....do this in each chamber.hope this helps!! or go d 16 if your strapped for funds.if not go b16!
goobous
Jan 2, 2010 11:57 PM
crazykamper
Oct 15, 2006 08:31 PM
