Turbo H22a problem????????????????
Old Jan 1, 2006 | 03:17 PM
rhemu1's Avatar
Default Turbo H22a problem????????????????
I have a turboed H22a in my 92 prelude and the problem is that I finally got everything completed and went to drive it and I couldn't get the car past 2200 rpm's I can't figure out the problem Im thinking it might be my Ecu the entire swap was bought from a friend of mine excluding the motor he had a turbo H22a in his civic and the parts i got from him were as followed a t3/t4 turbo manifold and turbo intercooler walbore 255 fuel pump AEM fuel pressure regulator p28 ecu tuned with hondata with boost option full throttle shift and launch control. a Nology ignition ampilfier and oil catch can. Does anyone have any Idea what the problem is I don't get any blue or white smoke out the tail pipe and the car runs and Ide's perfect. I didn't do a compression test yet but I don't think its a motor problem please help.
Old Jan 1, 2006 | 03:49 PM
BlueLude94's Avatar
Default Re: Turbo H22a problem???????????????? (rhemu1)
Describe the problem, Why can't you get it past 2200 rpms, does it feel like fuel cut, bogging down, cuts off or what?
Old Jan 1, 2006 | 04:17 PM
The Weather Man's Avatar
Hm.
While the vehicle is in neutral, can you rev past 2200?
Old Jan 1, 2006 | 04:40 PM
6E LUDE's Avatar
I kinda have the same problem. When I hits about 5500 rpms it, I guess i would say, it bogs and the car front end goes foward. I'm thinkin it might be the stock ECU and/or stock fuel system. Ideas?
Old Jan 1, 2006 | 04:42 PM
Well DUH! A stock ecu and a stock fuel system while boosting?.....don't you think SOMETHING is wrong with that? ................
Old Jan 1, 2006 | 04:54 PM
6E LUDE's Avatar
Well for the ECU should I get it modded? Replaced with another ECU? or Get Hondata s200? And I know what im getting for the fuel system.
Old Jan 1, 2006 | 04:55 PM
I say get the hondata s300 - s200 is outdated....still works fine, but the s300 is the future i guess. Have it professionally tuned also - you will gain a lot of whp that way.
Old Jan 1, 2006 | 05:01 PM
6E LUDE's Avatar
s300 doesn't seem to bad. That is also the problem, I never had the car tuned yet since the turbo kit. That is the next thing after I upgrade the ECU. Thanks man.
|8tz
Old Jan 1, 2006 | 05:05 PM
yeah. The s300 is great, i own one myself. I was actually doing some things with my car earlier. Read up on it. You can also download the software for free on hondata.com
Old Jan 1, 2006 | 05:16 PM
6E LUDE's Avatar
Did you install the s300 yourself? or someone else? I just read the "Details on preparing the ECU" and you have to De-solder and solder stuff on the ECU. I'm not good with that kind of stuff.
Old Jan 1, 2006 | 05:27 PM
I purchased mine ready to go. All i did was replaced the factory ecu and plugged in the USB cable.........if you go to the sponsor marketplace, you can find them all ready to go - or you can buy them not socketed and precisionh23a will do it for a small fee.
Old Jan 1, 2006 | 05:41 PM
6E LUDE's Avatar
Link to the ready to go in the sponsor marketplace? I looked all over can't seem to find one. Also what is your setup? You said you just plugged it in? You have anything modded? I believe I have a 3 bar Map sensor. Does that make a difference?
Old Jan 1, 2006 | 05:42 PM
The s300 has options for many different map sensors - just chose which one you're using and tune the baby. I'll find a link - hold on one sec.
Old Jan 1, 2006 | 05:59 PM
rhemu1's Avatar
Default Re: (TheKINGPin)
At 2200 rpm's it feels like Im hitting the rev limiter and it wont go past 2200 no matter what gear im in.
Old Jan 1, 2006 | 06:00 PM
Maybe you should check your boost cut. I know there's an option in hondata - just make sure you didn't accidentally set it at 1psi or something.
Old Jan 1, 2006 | 06:45 PM
6E LUDE's Avatar
You have any links? I still can't find anything.
Old Jan 1, 2006 | 06:50 PM
https://honda-tech.com/zerothread?id=1300672
https://honda-tech.com/zerothread?id=1258100
Those guys sell them. Ask them for a hondata s300 already socketed and everything. Price should be around $700 - i paid $717 with the p28 ecu and everything shipped.
Old Jan 1, 2006 | 07:48 PM
GaRn's Avatar
sounds like a bad MAP sensor to me.. alot of times they won't let you rev above 2,xxx rpms on several cars..
Old Jan 1, 2006 | 07:53 PM
flip1199's Avatar
Default Re: (rhemu1)
timing right? swap ecu's and see if it goes away..
Old Jan 1, 2006 | 07:55 PM
Default Re: (GaRn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GaRn &raquo;</TD></TR><TR><TD CLASS="quote">sounds like a bad MAP sensor to me.. alot of times they won't let you rev above 2,xxx rpms on several cars..</TD></TR></TABLE>
Exactly what i was thinking. If the factory ecus see boost....will they throw a code?
Old Jan 4, 2006 | 09:34 AM
GaRn's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheKINGPin &raquo;</TD></TR><TR><TD CLASS="quote">
Exactly what i was thinking. If the factory ecus see boost....will they throw a code?</TD></TR></TABLE>
it should yes, it would probably freak out and feel like running into a brick wall lol, but I have never seen or experienced it so I dunno..
Old Jan 4, 2006 | 02:02 PM
H22A_EJ2's Avatar
Default Re: (6E LUDE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 6E LUDE &raquo;</TD></TR><TR><TD CLASS="quote">I kinda have the same problem. When I hits about 5500 rpms it, I guess i would say, it bogs and the car front end goes foward. I'm thinkin it might be the stock ECU and/or stock fuel system. Ideas?</TD></TR></TABLE>
I was having these sort of problems with my h22 hybrid coupe, the first time a simple tune up took care of the problem, and then the second time I discovered that a wire running into my TPS sensor was cut.
Old Jan 4, 2006 | 04:19 PM
6E LUDE's Avatar
Default Re: (EJ2_Squadron)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ2_Squadron &raquo;</TD></TR><TR><TD CLASS="quote">I was having these sort of problems with my h22 hybrid coupe, the first time a simple tune up took care of the problem, and then the second time I discovered that a wire running into my TPS sensor was cut.</TD></TR></TABLE>Tune up? What kind you talking about? Plugs, wires, etc....that kind of tune up? Or do you mean Dyno Tune? I know I just have to get my car tuned by a dyno guy.
Old Jan 4, 2006 | 07:45 PM
T
U know what it is it's your launch control option. Mine was doing the same thing but at 3300 rpm and in any gear it was not going past that. Here's what I did I had an extra cable dangling and we had noticed that in one of the jumper cables it had an open spot so we connected the cable into the jumper harness. SO basically look through your engine bay, mine was just underneath the intake and on top of the tranny, locate and try to find a wire harness to jump it into. Or have your friend who had the setup before you help you determine what jumper to plug it into.
Old Jan 5, 2006 | 07:25 AM
rhemu1's Avatar
Default Re: (H22JDMEG)
Well I was think about the what exactly did on my swap as far as wiring goes and I remebered I forgot to wire up the intake air bypass solenoid do you think that is what my problem is??????????
