Type R throttle body
Is this a type R throttle body on my 99 si? I was told it was. I am just curious to what the vacum nipple on top is for. And my manual shows the throttle body should have 3 coolant lines to it, this has only 2. One in from intake, one out to iacv, and another out to engine oil cooler. Thanks for help.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkoundrelUSA »</TD></TR><TR><TD CLASS="quote">Best bet is to measure it (62mm I think)</TD></TR></TABLE>
yeah itrs are 62mm plus if he put this on stock manifold without port matching it its uselless because i think the port on a b16 manifold is only 60 mm.... unless he put an itr manifold on or an aftermarket one.
Thanks guys, I did shove my finger down there and didnt feel the manifold lip, so its port matched. Also, I dont need that nipple since my car is obdII and the evac takes car of the charcoal canister, correct?? So it being capped off is okay? Thanks
