Question about 1500civic, way back when
Old Jan 1, 2006 | 01:56 PM
epthr33's Avatar
Default Question about 1500civic, way back when
does anyone know what kind of motorswaps could be done into a 1982 civic 1500 dx 5-speed? especially interested to know if a k20a3 could fit, or even any crx si motors? just trying to get an answer for a friend and i'm kind of curious too, thanks.
Old Jan 1, 2006 | 02:14 PM
crx2nr822's Avatar
Default Re: Question about 1500civic, way back when (epthr33)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by epthr33 &raquo;</TD></TR><TR><TD CLASS="quote">does anyone know what kind of motorswaps could be done into a 1982 civic 1500 dx 5-speed? especially interested to know if a k20a3 could fit, or even any crx si motors? just trying to get an answer for a friend and i'm kind of curious too, thanks. </TD></TR></TABLE>
ALOT of fabrication if you want to swap b series, h series, k series.........but I'm sure it would be alot easier to bolt a d series engine in there, but I dont know if it would bolt directly up. Plus you would have to change alot of wiring to get it to adapt to the motor swap.
Old Jan 1, 2006 | 02:37 PM
1point7db2's Avatar
Default Re: Question about 1500civic, way back when (crx2nr822)
I've got an 81' 1300 DX. I have heard that a 78' - 84' Prelude/Accord motors are a drop-in affair, and no wiring is needed because they are carb'd. these motors are 1.8 I beleive, and have PLENTY of power to scoot the light *** little cvcc around, that would be the easiest swap. I have seen d series swapped in, but you must make custom mounts and swap a whole wiring harness in as well. You will also need higher fuel pressure for the F.I. system.
Old Jan 3, 2006 | 01:55 AM
epthr33's Avatar
Default Re: Question about 1500civic, way back when (blownEG93)
very helpful, thanks alot guys.
sohcrx91331
Aug 16, 2009 04:58 PM
Tom123456
Jan 14, 2007 09:37 PM
Mavrick
Sep 17, 2005 05:45 AM
MassCivicMan987
Dec 16, 2004 07:42 AM
