gsr brakes identification
Old Jan 1, 2006 | 01:15 PM
bigfuhrm's Avatar
Default gsr brakes identification
I have gsr front brakes on my 91 si, i want to know how to tell what year they are from. I am putting them on my 2000 hatch. thank you
Old Jan 1, 2006 | 02:09 PM
Gunns's Avatar
Default Re: gsr brakes identification (bigfuhrm)
I dont think there is a way to tell what year car the brakes are from. All 94-01 RS, GS, GSR brakes are the same. There is no advantage to "GSR" brakes. As long as the rotors and pads are in good shape who cares really? Better stopping power right.
Old Jan 1, 2006 | 02:45 PM
bigfuhrm's Avatar
Is there a more positive way i could find out.
Old Jan 2, 2006 | 03:05 AM
tmramsburg's Avatar
any one
Old Jan 11, 2006 | 02:26 AM
Redline96LX's Avatar
* B A N N E D *
Default Re: (tmramsburg)
go take a picture.
90-93 Integras (one of the models at least) is labeled 17CL14VN. maybe this helps some.
Old Jan 11, 2006 | 07:27 AM
tmramsburg's Avatar
How do you put up pics? I will buy that prop valve, will u ship to baltimore,MD for $45?
Old Jan 11, 2006 | 07:52 AM
sockvtec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tmramsburg &raquo;</TD></TR><TR><TD CLASS="quote">How do you put up pics?</TD></TR></TABLE>
http://www.imageshack.us host it there...
and if you have the 88-91 chassis i think you would be using the 90-93 integra brakes not he 94-01 brakes..but in case they are the 94-01 they will fit fine on your hatch
and like thy guy said before me it dont matter what year or trim they are they are all the same 94-01 that is..the type r brakes are different tho duh
Old Jan 12, 2006 | 07:21 PM
tmramsburg's Avatar
Let me know if i did it right. I never did this before.
Old Jan 12, 2006 | 07:50 PM
KillBot's Avatar
Default Re: (Redline96LX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Redline96LX &raquo;</TD></TR><TR><TD CLASS="quote">
90-93 Integras (one of the models at least) is labeled 17CL14VN. maybe this helps some.</TD></TR></TABLE>
Since your pic has "17CL14VN"...I'll guess 90-93..
Old Jan 12, 2006 | 11:08 PM
* B A N N E D *
Default Re: (KillBot)
I THINK that 94-01 Integras calipers also have that number in them. What I do know is that I think its a 94-01 Integra caliper because the side retainer springs have those curvy things where 90-93 integra brackets take a differenent shaped side retainer spring.
So unless someone can proove me wrong, I'ma go and say 94-01 Integra calipers.
Old Jan 13, 2006 | 09:45 AM
JDMFreak's Avatar
will 94 civic ex with abs rear disc fit 99-00 civic?
Old Jan 13, 2006 | 09:50 AM
pdiggitydogg's Avatar
If theyre DC, the piston will be 57mm diameter
I am not sure what number is stamped on my teg calipers...but the clips are curvy like that
yes, the ex abs calipers will fit a 00 em1 (since their pattern is the same as integra, which is the same as standard ex, which is the same as em1)
Old Jan 13, 2006 | 03:45 PM
tmramsburg's Avatar
[img=http://img295.imageshack.us/img295/9666/picture2451um.th.jpg]
Old Jan 13, 2006 | 04:49 PM
knuckle arm...for?
Old Jan 30, 2006 | 03:36 PM
JDMFreak's Avatar
Default Re: (pdiggitydogg)
i will clean my brake set up off of a 94 civic ex-abs in a couple of days, and take pictures of all number stamps that i see. i hope this well help out
Old Jan 30, 2006 | 04:03 PM
* B A N N E D *
yo, that large caliper picture is from a 94-01 Integra (exc. Type-R) based on the fact that those are its number and retainer clips. 90-93 Integras retainer clips dont go round and stick out like those.
Bobby_Budds
Suspension & Brakes
57
Jan 22, 2016 01:24 PM
Momentum
10
Jul 17, 2008 09:20 AM
TurboJDM
Jan 14, 2008 05:19 PM
slickciv
Jul 6, 2006 06:20 AM
Scotty Dosent Know
Dec 9, 2005 08:02 PM
