1996 accord insufficient flow for EGR...please help!!
Old Jan 1, 2006 | 11:54 AM
hjolley3's Avatar
Default 1996 accord insufficient flow for EGR...please help!!
The check engine light has been on for over a year, and every diagnostic says that we have an insufficient flow to the EGR valve. We have replaced the valve itself, the solenoid controling the air flow, cleaned all of the hoses connecting to it, and we have also cleaned the intake manifold. Each time we reset the light. The longest it has ever stayed off was 48 hours. After coming back on today, another diagnostic stated the same thing again. If anyone has any comments it is greatly appreciated. Thanks
Heather and Rob
Old Jan 1, 2006 | 02:15 PM
YeuEmMaiMai's Avatar
Default Re: 1996 accord insufficient flow for EGR...please help!! (hjolley3)
remove the fuel rail and injectors then remove the egr access plate on the intake manifoldf and use a pipe cleaner to clean the passageways. reassemble using self taping screws to reattach cover. IF your car hesitates around 2-2.5K then this is the cause.
Modified by YeuEmMaiMai at 5:50 PM 1/1/2006
Old Jan 1, 2006 | 02:43 PM
P_Adams's Avatar
Listen to the man; Him Speakith the truth !!!
P
Old Jan 1, 2006 | 05:04 PM
hondadude's Avatar
This link might be a great help to you
http://members.troublecodes.ne...R.htm
My very best friend worked hard to make this info available
Old Oct 22, 2007 | 10:37 AM
Calitech's Avatar
Default Re: 1996 accord insufficient flow for EGR...please help!! (YeuEmMaiMai)
I have the same problem; I cleaned out all of my manafold passages and still have the problem. I replaced the egr, I think it is a wrong output voltage leading to the solenoid. the egr valve is not lifting all the way. It is coming up as a p0401, but the problem is more like a p1491 "insuffecent egr valve lift" please post me if you find out what is wrong.
burnhamr
Sep 16, 2023 10:32 PM
themiz816
Aug 23, 2014 05:12 AM
Adam_F123
Nov 15, 2008 08:53 AM
Vtec9778
Oct 21, 2008 03:42 PM
mtn_biker_lpw
Jun 9, 2007 11:18 AM
