ruff idle on zc
Old Jan 1, 2006 | 10:51 AM
CjRdXmsi's Avatar
Default ruff idle on zc
i just replaced my Idle Air Control valve and that didn't fix the idling. I've tried adjusting the idle but stays right at about 800rpms. sometimes the rpms will go up and down a little bit. help please.
Old Jan 1, 2006 | 01:00 PM
9mm's Avatar
9mm
Default Re: ruff idle on zc (CjRdXmsi)
my guess would be check all your vacuum lines for leaks
Old Jan 1, 2006 | 01:03 PM
efgarage's Avatar
make sure your tps in within range also
Old Jan 2, 2006 | 08:51 PM
CjRdXmsi's Avatar
Default Re: (efgarage)
yea i checked my ecu and my tps came up so i have to check that out
Old Jan 3, 2006 | 08:02 AM
CjRdXmsi's Avatar
Default Re: (CjRdXmsi)
should i just relpace my TPS or is there anything i can do?
Old Jan 3, 2006 | 08:09 AM
crxluv2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CjRdXmsi &raquo;</TD></TR><TR><TD CLASS="quote">should i just relpace my TPS or is there anything i can do?</TD></TR></TABLE>
adjust it
Old Jan 4, 2006 | 08:36 AM
CjRdXmsi's Avatar
Default Re: (crxluv2)
it still has the stock rivets in it so i have to wait till i get the tool to take them out to adjust it
b18hondahb
16
Oct 13, 2006 05:40 PM
SOLO1racer
Feb 9, 2005 09:06 AM
hatchinprogress
Oct 10, 2004 11:19 AM
