GSR IACV & Skunk 2 Intake Manifold
Old Jan 1, 2006 | 10:37 AM
Touch's Avatar
Default GSR IACV & Skunk 2 Intake Manifold
From my understanding the 96 and up iacv is shorter than the 94-95 GSR iacv. So I'm doing a skunk 2 pro series intake manifold swap, and was looking to buy an outlawengineering gasket kit http://www.outlawengineering.c....html and I'm not certain if my 94 gsr iacv will fit onto the new intake manifold. If not I will need to buy a new one. If anyone knows or has any info, please let me know. Thanks in advance.
Modified by Touch at 3:07 PM 1/1/2006
Old Jan 1, 2006 | 10:59 AM
85mm LS VTEC's Avatar
Default Re: GSR IACV & Skunk 2 Intake Manifold (Touch)
What do you mean by shorter? The wires to plug it back in? The IACV should bolt right up to the manifold. It would be a good idea to replace the o-ring seal when mating the valve to the manifold. My GS-R IACV fit good with no problems.
Old Jan 1, 2006 | 11:07 AM
Touch's Avatar
Default Re: GSR IACV & Skunk 2 Intake Manifold (85mm LS VTEC)
the actual module is shorter on the later version teg's iacv.
I wanted to order this kit, but at the bottom, they say that the iacv gaskets are different.
ThermoBlok SPACER KIT - 94-95 Acura B18C1 1.8L VTEC
Includes intake manifold spacer, throttle body spacer, IAC spacer, gaskets, installation kit, bypass fitting, detailed instructions and OUTLAW ENGINEERING decals!
Price: $99.00 plus shipping ($6 US & Canada)
NOTE: THE IACV changed from 95 (long) to 96 (short). Be sure to order the correct kit for your vehicle.
slvrslepr
Apr 23, 2013 10:08 PM
Touch
Mar 12, 2008 06:39 PM
Touch
Apr 10, 2006 10:14 AM
Touch
Jan 2, 2006 07:09 AM
