ground wires question
i got a ground wires set and a voltage stablizer, where exactly i should connect the wires, i guess for honda they r 4 wires, can u plz tell me exactly where i should put them, and pics will be help full too, i have a d15b vtec
chassis to trans housing, daisy chaining to engine block,
chassis to cylinder head, daisy chaining to valve cover,
chassis to alternator,
chassis to ECU/sensor ground point at thermostat housing
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by andrey320 »</TD></TR><TR><TD CLASS="quote">chassis to trans housing, daisy chaining to engine block,
chassis to ECU/sensor ground point at thermostat housing</TD></TR></TABLE>
Well there is a start. To really make a substantial Hp gain with ground wires, you need to have the car on a dyno and keep trying different locations until you get the best combo. Only then will you really know how much the difference the ground wires made in power.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx2nr822 »</TD></TR><TR><TD CLASS="quote">Well there is a start. To really make a substantial Hp gain with ground wires, you need to have the car on a dyno and keep trying different locations until you get the best combo. Only then will you really know how much the difference the ground wires made in power.
upgrading ground wires is not exactly for power.
</TD></TR></TABLE>upgrading ground wires is not exactly for power.
gabrielsousa
May 21, 2014 08:21 AM
dingusjt
20
Mar 6, 2003 09:03 PM
