GSR cluster in CRX
Old Jan 1, 2006 | 06:02 AM
Beau Gotti's Avatar
Default GSR cluster in CRX
how hard is this to do, much wiring?
Old Jan 1, 2006 | 06:04 AM
crexer's Avatar
Default Re: GSR cluster in CRX (Beau Gotti)
https://honda-tech.com/zerosearch
Old Jan 18, 2006 | 09:12 AM
crxsir07's Avatar
Default Re: GSR cluster in CRX (crexer)
I found links for the Civic Si cluster swap, so i did the wiring and the Civic cluster works sweet, but i assumed since the clips are the same for the DC2 it work work also (got the hopes up haha) every thread i've found about the DC2 pinouts is old or expired college sites (oregon state) that don't work, does anyone have the DC2 pinouts and there corresponding funtions? I have a DC2 cluster already and really don't want to spend 400 on an Si cluster
Old Jan 18, 2006 | 09:40 AM
crxsir07's Avatar
Default Re: GSR cluster in CRX (crxsir07)
anybody?
Old Jan 18, 2006 | 10:04 AM
B18 CYA's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxsir07 &raquo;</TD></TR><TR><TD CLASS="quote">anybody?</TD></TR></TABLE>
i have a 94 gsr cluster wired in my car, if i get around to it sometime soon ill copy down the color-color for you!
Old Jan 20, 2006 | 12:40 AM
crxsir07's Avatar
Default Re: GSR cluster in CRX (B18 CYA)
Awesome, i would really appreciate it thanks alot!
Old Jan 20, 2006 | 09:59 AM
B18 CYA's Avatar
i put it so its integra clip #--------crx clip number
also c709 (12p connector on crx) 710 (8pin connector)
B1 Red/Blue Fuel gauge ---------C710 #3 Yellow/white
B2 empty
B3 Yellow/Black Seat belt light Empty
B4 Green/Yellow Low fuel light Not used unless you use a 90-93 integra fuel level guage
B5 empty
B6 Orange Speedometer Splice in with signal from vss in the tranny
B7 Blue/Black Trunk/hatch open -----------C710 #5 Green/Black
B8 empty
B9 Red Brightness --------------C709 #9 Red/Black
B10 Red/Black Gauge lights ----------C709 #8 Red
B11 Black/White color varies VSS Run the electronic Vss to here and also attach to the orange where b6 is ran..
B12 empty
B13 Green/Red-1 Silver Stripe Left turn signal ----------C709 #12 Green/Blue
B14 Green/Yellow-1 Silver Stripe Right turn signal -----------C710 #1 Green/Yellow
B15 Red/Green n/a not used
B16 Green/Red Emergency brake --------C709 #6 Green/Red
C1 empty
C2 empty
C3 empty
C4 Yellow Dimmer ---------C710 #2 Black/Yellow
C5 empty Cruise control empty
&lt; C6 empty Empty empty
C7 Black Black Ground ---------C710 #8 Black
c8 Yellow/green Brightness ---------C709 #10 Yellow/Green
C9 White/Blue Battery --------C709 #2 White/Blue
C10 empty
C11 Yellow/Red Oil pressure --------C709 #5 Yellow/Red
C12 Green/Orange Check engine -----C709 #4 Green/Org
C13 Blue Tachometer ---------C710 #2 Blue
Old Jan 20, 2006 | 10:17 AM
hatchinprogress's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18 CYA &raquo;</TD></TR><TR><TD CLASS="quote">
i have a 94 gsr cluster wired in my car, if i get around to it sometime soon ill copy down the color-color for you!</TD></TR></TABLE> post pics
Old Jan 20, 2006 | 12:55 PM
B18 CYA's Avatar
Default Re: GSR cluster in CRX (hatchinprogress)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchinprogress &raquo;</TD></TR><TR><TD CLASS="quote"> post pics </TD></TR></TABLE>
i dont have any pics of it in my car, but i have a pic of before i put it in when i got the cluster attached to the hood.
and here a little in-car night action of it
http://media.putfile.com/night-cluster
Old Jan 20, 2006 | 04:29 PM
2kTeg's Avatar
the early model DA integra cluster is much easier of a swap because its got the cable speedo looks good also
Old Jan 21, 2006 | 12:08 PM
FakeJDMEF8's Avatar
still dont have my vss wired up...anyone wanna help me....im REALLY confused...
Old Jan 21, 2006 | 01:30 PM
Vtakkk's Avatar
Default Re: (FakeJDMEF8)
Say I got a 94ish LS cluster, is there a how-to on how to install it ? ? ? Ive never done wiring before, and Most likely id screw it up hella bad.
Old Jan 21, 2006 | 02:38 PM
B18 CYA's Avatar
Default Re: (EFSTUD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EFSTUD &raquo;</TD></TR><TR><TD CLASS="quote">Say I got a 94ish LS cluster, is there a how-to on how to install it ? ? ? Ive never done wiring before, and Most likely id screw it up hella bad.</TD></TR></TABLE>
same **** as gsr dude, look at what i posted above about which wire to which wire there all the same for 94-97 clusters, some wires on 98+ are different tho
Old Jan 21, 2006 | 03:54 PM
donaldmejr's Avatar
What year range is that hood for? Is it a 90-91 crx si? And if so will it fit on a 88 crx si dash? Or will I need a 90-91 dash and hood to make this work? Or will and Integra hood bolt up to my 88 crx si dash??
Old Jan 21, 2006 | 04:45 PM
B18 CYA's Avatar
the hood in the pic is from a 91crx, it will work with any 88-91 crx/civic, but it fits better in the 90-91 hood cause its more round like the cluster. all year hoods are interchangable. and no the interga one will not bolt up unless you happen to do a dash swap which is alot of work!
Old Jan 21, 2006 | 11:19 PM
Vtakkk's Avatar
Default Re: (B18 CYA)
My friend said all we have to do it cut the wires on both dashes andjust match them up. is this true, thats all thats needed ?
Old Jan 22, 2006 | 05:45 AM
B18 CYA's Avatar
no, some of the colored wires on the gsr do different stuff then on the crx. follow what i posted.
Old Jan 22, 2006 | 01:46 PM
donaldmejr's Avatar
will a 90 integra ls cluster fit into a 1988 crx si with a flat top hood if so then I having troble making it fit into the stock location. Yes I did remove the old mounting brackets
OR do I have to shave
Modified by donaldmejr at 4:03 PM 1/22/2006
Old Jan 22, 2006 | 02:02 PM
4DRmafia's Avatar
i wonder too .....da will work ?
Old Jan 22, 2006 | 03:03 PM
donaldmejr's Avatar
Default Re: (donaldmejr)
Help!
Old Jan 22, 2006 | 04:24 PM
crxsir07's Avatar
Hey Thanks alot B18 CYA!
Old Jan 22, 2006 | 04:50 PM
B18 CYA's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by donaldmejr &raquo;</TD></TR><TR><TD CLASS="quote">will a 90 integra ls cluster fit into a 1988 crx si with a flat top hood if so then I having troble making it fit into the stock location. Yes I did remove the old mounting brackets
Modified by donaldmejr at 4:03 PM 1/22/2006</TD></TR></TABLE>
yeah it will work, you might want to shave those parts, i didnt, but when i pull it out or put it in it gets kinda stuck but if you work it, it fits
Old Jan 22, 2006 | 06:57 PM
Ak_ef9's Avatar
here is the links I will be using
http://www.angelfire.com/dc/oregonimport/gsr.html
https://honda-tech.com/zerothread?id=458873
https://honda-tech.com/zerothread?id=274235&page=5
Old Jan 22, 2006 | 08:30 PM
donaldmejr's Avatar
Default Re: (Ak_ef9)
Yeah I found those but will that work for my 90-93 da cluster??
Old Jan 22, 2006 | 10:48 PM
B18 CYA's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by donaldmejr &raquo;</TD></TR><TR><TD CLASS="quote">Yeah I found those but will that work for my 90-93 da cluster??</TD></TR></TABLE>
best way to check is to use a multimeter and see which wire goes where...thats what we did for mine.
wow_ohoh
Jun 29, 2009 08:16 AM
B_CRUZ!
Northern California (Sales)
Nov 10, 2005 10:49 PM
tvman
Oct 26, 2005 04:08 AM
