auto to manual timing belt tensioner
ive checked. and in the link that is in the FAQ section is not available anymore. anybody know of a link that works for instructions on how to do this? thank you
Check out ultimateresourceguide, they have the par #'s and instructions on how to do this. It costs a little to download the software, but it's worth it.
H23 Manual Tensioner
What you need:
13404-PT0-004 - ADJUSTER COMP., BALANCER BELT
13415-PT0-000 - BRACKET, BALANCER BELT ADJUSTER
14510-PT0-004 - ADJUSTER COMP., TIMING BELT
14516-PT2-000 - SPRING COMP., TIMING BELT ADJUSTER
14521-P14-A00 - PLATE, ADJUSTER
90014-P14-A00 - BOLT, TIMING BELT ADJUSTER BASE
90015-PT0-000 - BOLT, TIMING BELT ADJUSTER SPRING
90016-PT0-000 - BOLT, TIMING BELT ADJUSTER
90140-P14-A00 - WASHER, PLAIN (11MM
This is the parts list I used when I did mine. I used to have a link on collectiveracing.net but it is no longer working. I would hit up 2point6 for the write up.
What you need:
