climate control in cx
Old Dec 31, 2005 | 05:27 PM
kyorishin's Avatar
Default climate control in cx
yah ive been notcing this for a while and was jsut wondering y mine donest light up ? is it just cuase the cx model never came wit the blubs or is it my wiring?
Old Dec 31, 2005 | 05:55 PM
civicliveit's Avatar
Default Re: climate control in cx (kyorishin)
the bulbs must be burned out. they are little bulbs and avail thru honda.
Old Dec 31, 2005 | 06:00 PM
JDM-EJ1's Avatar
Default Re: climate control in cx (civicliveit)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicliveit &raquo;</TD></TR><TR><TD CLASS="quote">the bulbs must be burned out. they are little bulbs and avail thru honda. </TD></TR></TABLE>
Or you can get them at your local autoparts store. I forget what size they are.
Old Dec 31, 2005 | 06:20 PM
95sivee's Avatar
Default Re: climate control in cx (JDM-EJ1)
small bulbs: 74 big bulbs: 194
Old Dec 31, 2005 | 06:22 PM
JDM-EJ1's Avatar
Default Re: climate control in cx (95sivee)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95sivee &raquo;</TD></TR><TR><TD CLASS="quote">small bulbs: 74 big bulbs: 194</TD></TR></TABLE>
They use two of the 'small' bulbs. So, you would want to replace them with two 74 bulbs.
Tippyman's Avatar
check wiring and fuses before you buy bulbs...
Old Dec 31, 2005 | 06:25 PM
JDM-EJ1's Avatar
Default Re: (Tippyman98)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tippyman98 &raquo;</TD></TR><TR><TD CLASS="quote">check wiring and fuses before you buy bulbs...</TD></TR></TABLE>
The only way to check the wiring would be to pull the climate itself (I'm talking about the wiring directly to the bulbs). And if his gauge cluster lights work, then that rules out a fuse being bad.
More than likely it's burn out bulbs. That climate can be a bitch to get out though, I hate taking mine out.
vtec2K9
Lighting
Jul 3, 2008 08:44 PM
Da1Gsr
Mar 6, 2006 07:03 PM
bm3r
Sep 30, 2004 05:57 PM
Viorent Grip! EG
15
Jun 7, 2004 01:54 AM
TheHater
Jan 13, 2003 10:18 AM
