Need help with ruff idle
Old Dec 31, 2005 | 04:47 PM
Chris1112's Avatar
Default Need help with ruff idle
I have a 1994 Honda accord that has 210,000 miles on it. The car has started to idling ruff. The car has slight hesitation when you first start. When you are driving the car at about 1700 rpms the car has a slight stutter but other then that the car runs fine.
There are no warning lights that are coming on. I have changed the air filter, spark plug wires, spark plugs, fuel filter, checked for vacuum leaks, and made sure that the egr valve opens and closes properly. Any body got any ideas on what could be causing the car to run like this.
Old Dec 31, 2005 | 08:26 PM
hondadude's Avatar
Default Re: Need help with ruff idle (Chris1112)
for the idle quality you might first try cleaning out the throttle body around the 'butterfly' there could be a ring of crud built up Link below
http://members.troublecodes.ne...n.jpg
For the other problem of stumble during accelleration around 1700 rpms; here is another link for cleaning EGR ports
http://members.troublecodes.ne...R.htm
Old Jan 2, 2006 | 09:35 AM
Chris1112's Avatar
Default Re: Need help with ruff idle (hondadude)
Thanks for the information. I will give it a try.
david1227
Jun 2, 2013 11:50 AM
Ntense_Civic
Apr 20, 2012 04:47 PM
jojogalan
18
Jul 14, 2007 11:51 PM
gtgoku
15
Feb 9, 2005 09:43 AM
Outkast95LS
Dec 27, 2004 05:36 AM
