what first?
Old Dec 31, 2005 | 04:40 PM
importsk8er's Avatar
Default what first?
Ok, so I want to have a fully built sohc d16z6 in my '95 ej1 coupe. My future plans are to have it boosted with a Greddy turbo kit, intercooler kit, and TT exhaust. I want to do some internal modifications first. I dont know what to do first though.
-Bigger fuel injectors, AEM fuel rail.
-Skunk 2 cam shaft, AEM cam gear, and AEM pulleys.
-Skunk 2 turbo valve springs, and Skunk 2 valves.
I'm a new member, so any help would be great. Thank-you.
Old Dec 31, 2005 | 04:43 PM
littleredcivic's Avatar
based off what you posted, just buy the kit and don't do any additional mods. you don't need those parts first, nor will you need them if you are not boosting high.
Old Dec 31, 2005 | 04:54 PM
ok I will buy the kit first then, but I have 130,000 miles on my motor. I plan on boosting over 10lbs so I think it does need some internal work.
someone?
Old Dec 31, 2005 | 05:24 PM
nekoabandoned's Avatar
Default Re: (importsk8er)
well it all depends on the kit ur getting, what it comes with. first tell me what comes with the kit and ill try to help and internal isnt injectors or fuel rails
Old Dec 31, 2005 | 05:35 PM
i was thinking about the greddy turbo kit. You have to buy the intercooler kit seperate.
If i wanted to do stuff liek valve springs first, could i get the turbo valve springs from skunk 2 with out being turbo?
Old Dec 31, 2005 | 05:45 PM
wob's Avatar
wob
i wouldnt waste my money on the greddy kit, ur gonna buy it, and after a few months ur gonna want something more, and greddy probably cant help u with that.. build ur own kit..
as for internal modifications... imho leave it stock just get a nice tune.. unless ur trying to make sick numbers that is...
Old Dec 31, 2005 | 05:53 PM
dohcVTECeg2's Avatar
Default Re: (wob)
you dont really need to buy internals unless you are planning on boosting the hell out of that d16. just pick up a cam shaft and cam gear and it should help.
Old Dec 31, 2005 | 10:16 PM
so you guys think i should make my own kit. i was thinking about the greddy kit but it would be expensive. the turbonetics kit is cool also...it said my horsepower would be at 200 rather the stock 125 with 8 psi.
o yeah...i was also planing on keeing the A/C and power stearing.
Old Dec 31, 2005 | 10:59 PM
you need to first come up with a budget.
Old Jan 1, 2006 | 01:13 AM
SaNgErEM1
Guest
Posts: n/a
Default Re: what first? (importsk8er)
I would first get the turbo kit and then go from there. But you say the car has 130,000 miles which is kind of high and when you look at it with all the money you are going to spend on the turbo kit, fuel system, and the engine rebuild you might as well just use that money to swap in a B-series or H-series.
Old Jan 1, 2006 | 01:53 AM
DasaEJ1's Avatar
Default Re: what first? (EKhatchFREAK)
yeah I rather go with a custom turbo kit...you would be better off with that then greddy...you should get a jdm single cam d15b vtec...if you want to boost high then get a external wastegauge and some APR headbolts...that should be pretty safe to boost over 5 pounds...dont know how much you would be able to boost.
Old Jan 1, 2006 | 02:10 AM
9295EJ-t's Avatar
i boosted one of my ej's after it rolled over 195,000 miles... ran like a champ!
but i was rear ended by a moving truck..
the motor is coming out and going into my ej2..
as long as you arent burning oil, have no leaks.. you should be fine for a while staying under 10psi..
over 6psi, i recommend ARP headstuds.. head lift is common in d-series..
get a felpro 3-layer steel headgasket, headstuds.. and boost away!
if you wanna read up more about boosting your z6, i recommend http://www.turbod16.com the gurus of boosted z6's live here..
Old Jan 1, 2006 | 07:47 AM
99 Civic EX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EKhatchFREAK &raquo;</TD></TR><TR><TD CLASS="quote">I would first get the turbo kit and then go from there. But you say the car has 130,000 miles which is kind of high and when you look at it with all the money you are going to spend on the turbo kit, fuel system, and the engine rebuild you might as well just use that money to swap in a B-series or H-series.</TD></TR></TABLE>
130,000 miles is fine for boost, other people have boosted on much higher mileage with no problems at all. in my opinion, just buy the turbo kit for the d16 and i think you will be more than happy with it.
S2KRIDERAP2
May 22, 2010 08:09 PM
dmorris05
Honda Civic (2001 - 2005)
49
May 18, 2007 07:36 PM
92CivicSIRhb
Feb 18, 2005 01:08 PM
civic2nr9177
Dec 5, 2003 08:14 PM
10secondr33
Aug 31, 2003 08:22 PM
