EIBACH Wheel Spacers
Old Dec 31, 2005 | 04:28 PM
IMPACT's Avatar
Default EIBACH Wheel Spacers
Hey guys I did a search on the EIBACH wheel spacers and came up empty. I was wondering if anyone has used them before. They are supposed to make your tires fill the tire well. Give you that "wider stance" look.
Any feedback would be killer.
Thanks in advance,
Old Dec 31, 2005 | 07:45 PM
SpoolnEG6's Avatar
Default Re: EIBACH Wheel Spacers (IMPACT)
I personally do not like wheel spacers but the eibach or h&r are the best due to the fact that they are made hubcentric to the vehicle. I highly recommend them to people at work when they are looking into spacers but they have a higher price tag than the universal. What kind of vehicle do you have? Also to find out how thick of a spacer you need measure the distance between the top of the tire and the inside of the fender.
http://eibach.com/cgi-bin/html...19519
Old Jan 1, 2006 | 06:07 AM
IMPACT's Avatar
Default Re: EIBACH Wheel Spacers (SpoolnEG6)
Hey there Spooln, I have a 95 Teg. I'm in the process of doing a JDM SiR-G conversion on it. I would like to give the car a wider stance if possible, I just threw the EIBACH brand out there. If there are any other brands that you know of that would be great info.
Old Jan 1, 2006 | 10:45 PM
SpoolnEG6's Avatar
I don't know what wheels you have on there but if your gonna buy a set depending on size, say a 15x7 w/ a lower offset will bring the wheels out toward the fenders more. Also I wouldn't space out any more than 5mm. I would definetley recommend longer wheel studs to be safe if you decide to do it just as a safety precaution.
Old Jan 3, 2006 | 10:58 AM
IMPACT's Avatar
Cool man, I have Rota Slipstreams with Toyo Proxes T1-S 205-45-16 on them. Thanks for the info....good info...
Old Jan 3, 2006 | 11:44 AM
SpoolnEG6's Avatar
5mm Eibach Spacer part number is 90.5.05.005.1
this is the 5mm spacer for an integra assuming you still have the 4 lug on it
Old Feb 5, 2006 | 10:07 AM
Armaan's Avatar
http://www.superstreetonline.c....html
Not a Honda, but I have tried them on this Celica, and they wheels, both under acceleration and under heavy braking, remain true and vibration-free. If you want to increase the track, I'd definitely recommend Eibach. Just be sure to press the new (included) studs into your hubs.
Old Feb 6, 2006 | 10:09 PM
hadboosttroy's Avatar
Default Re: EIBACH Wheel Spacers (Armaan)
h&r trak
localev
May 21, 2006 12:35 PM
Chris F
Mar 28, 2005 06:58 AM
Catch 22
Aug 15, 2003 01:33 PM
ek4life
Audio / Security / Video
Mar 19, 2002 04:59 PM
