Nuts and bolts
You can use a tamper resistant Torx screw like this one
(top view)
Or a Hex Screw
Just a suggestion. You can still get past them but it is a pain, trust me I know.
Most of this stuff you can find at McMaster-Carr (http://www.mcmaster.com)
Cheers!
(top view)
Or a Hex Screw
Cheers!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkoundrelUSA »</TD></TR><TR><TD CLASS="quote">Don't they just rip it off anyway? Unless you make more holes for bolts somehow, I don't know...</TD></TR></TABLE>
If they rip it off, you can pretty much count on them being fucked for using it again.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by old man neri »</TD></TR><TR><TD CLASS="quote">You can use a tamper resistant Torx screw like this one
(top view)
Or a Hex Screw
Cheers!</TD></TR></TABLE>
i dont see how those will work cuz the spoilers have the threads on them and its fastened on by a nut with a dome shape at the end. im not really worried about it getting ripped off since it would be useless to them anyways.
(top view)
Or a Hex Screw
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WayQuiz »</TD></TR><TR><TD CLASS="quote">
i dont see how those will work cuz the spoilers have the threads on them and its fastened on by a nut with a dome shape at the end. im not really worried about it getting ripped off since it would be useless to them anyways.</TD></TR></TABLE>
I wasn't really sure what specific mounting method you were talking about to begin with.
The nut you are refering too is called an acorn nut.
Other solutions with nuts are
Break away nut, once installed it will just break away if you try to remove it.
Serrated edge nut
Spanner nut
Tri-grove nut
Again, all available at McMaster-Carr. http://www.mcmaster.com Just search for "tamper resistant nuts"
Cheers and good luck!
Serrated edge nut
Spanner nut
Tri-grove nut
Serrated edge nut
Spanner nut
Tri-grove nut
Cheers and good luck!</TD></TR></TABLE>
NICEEEE! I appreciate the help. I think I'm gonna go with the break away nut
Serrated edge nut
Spanner nut
Tri-grove nut
HBADGE
Aug 24, 2005 05:00 PM
