98 honda accord, coolant fans are not working
Old Dec 31, 2005 | 12:15 PM
edcpus's Avatar
Default 98 honda accord, coolant fans are not working
Maybe someone can help. I have a 98 honda accord lx 4 cyl. the problem i am having is the cooling fans will not kick on, i have replaced two temperature sensors, and fans will not kick on, If i turn on the a/c the fans will work. Once i turn it off they won't work. I change the antifreeze and the lower radiator hose a couple days ago, however the fans were working before then. The fans are brand new, i have check all fuses and relays. Can someone please help me
Old Dec 31, 2005 | 01:17 PM
hondadude's Avatar
Default Re: 98 honda accord, coolant fans are not working (edcpus)
How long did you let the car sit at idle? did the temp guage go above 1/2 way?
I'd like to have a little more info before I go looking up and uploading schematics; What's the rest of the story??
Old Dec 31, 2005 | 01:35 PM
edcpus's Avatar
Default Re: 98 honda accord, coolant fans are not working (hondadude)
ok im in alabama, so it ran for almost and hour before the temp guage went a couple inches to hot, but i shut the car off. However if im driving. the temp will rise up when im stop in traffic, but its sitting in my driveway and it will run hot, the radiator is still full, except after it starts to get hot before overheating the coolant resovior starts to boil.
Old Dec 31, 2005 | 01:54 PM
hondadude's Avatar
the switch that tells the fans to turn on is the one on top of the T-stat housing, you could try unplugging it and jumper the pins in the plug, then turn on the key and see if the fans run or if you hear any clicking noises from the relay;If there is a ground connector at the T-stat housing be sure it is hooked up and clean. I'll hang with ya here for awhile
Old Dec 31, 2005 | 02:11 PM
edcpus's Avatar
what do you mean by jumper the pins in the plug
Old Dec 31, 2005 | 02:14 PM
hondadude's Avatar
put a wire between the 2 terminals, you are faking a signal that the car is so hot the switch is closed
Old Dec 31, 2005 | 02:20 PM
edcpus's Avatar
that didn't work i have voltage on the plug itself though
Old Dec 31, 2005 | 02:22 PM
hondadude's Avatar
Do you have a meter? the other pin that doesn't have battery voltage should have continuity to ground. When you jumpered it did you hear the relay in the under hood fuse box 'click?
Old Dec 31, 2005 | 02:25 PM
hondadude's Avatar
Did you burp the block thru the 12mm bleed screw at the t-stat housing after adding coolant the other day?
Old Dec 31, 2005 | 02:28 PM
edcpus's Avatar
no i didn't hear the click
Old Dec 31, 2005 | 02:29 PM
hondadude's Avatar
Next thing to do is pull the relay from the underhood fuse box and jumper a cross the 2 slots that are lined up with the 'long side' of the relay this is jumpering the relay
Old Dec 31, 2005 | 02:49 PM
hondadude's Avatar
Voltage on one of the 'coil pins' when the fan switch is jumped, jumper across the contact pins to act as a 'closed' relay
Old Dec 31, 2005 | 03:35 PM
fixitman's Avatar
hey honda man this is edcpus is it anyway i can im you? ive tried all of the relays
Old Dec 31, 2005 | 03:44 PM
Honda-Master's Avatar
when engine is warmed up is the lower radiator hose almost as hot as the top hose,,,,,,if it is cool or warm you got a t-stat stuck close ,,and if that,s the case the fans will not come on ,,,,,,,,if the fans work with a/c on, it is not the fuses or the relays ,,,and you said you jumped the switch at thermostat housing and still did not work correct ??
Old Dec 31, 2005 | 03:52 PM
fixitman's Avatar
Default Re: (Honda-Master)
thats correct
Old Dec 31, 2005 | 03:58 PM
fixitman's Avatar
Default Re: (fixitman)
i know my access here is limited, but the lower radiator hose is cold after the car warms up, then the thermostat is not working, but how is it that it would cause the fans not to come on, are is there another idea
Old Dec 31, 2005 | 04:15 PM
hondadude's Avatar
You say the fans were working before you changed the lower hose?? Go back and see what you unplugged while doing that job....I'm looking for a full schematic to upload for you
Modified by hondadude at 7:47 PM 12/31/2005
Old Dec 31, 2005 | 04:45 PM
hondadude's Avatar
Default Re: (hondadude)
here's the BIG picture for your problem
http://members.troublecodes.ne...s.jpg
Old Dec 31, 2005 | 05:35 PM
fixitman's Avatar
ok i got diagram now what is actually wrong, i have replace the temperature switch, sensor, of course we know the relays are good. is it possible that the new sensor could be bad as well?
Old Dec 31, 2005 | 05:46 PM
BLKFLSH's Avatar
Did you burp the system? like hondadude said.
Old Dec 31, 2005 | 06:52 PM
hondadude's Avatar
Looking at the schematic...if you ground the green wire at the switch plug[key on] the relay should turn on and the fans run, I'm again asking that you review your prior work carefully to see if there is some thing that came unhooked while you were wrestling around with the radiator hose.
Old Dec 31, 2005 | 07:01 PM
if he said fans work with a/c on ,, it makes me assume that he connected everything properly around the fans .......i still say that if the lower radiator hose is cold when engine is hot , it has a stuck t-stat
Old Dec 31, 2005 | 07:08 PM
hondadude's Avatar
Thanks for jumping in on this one H-M.. earlier this evening I asked him to try jumpering the plug at the switch and he said the fans still did not run? I know that there must be some other problem??
Old Dec 31, 2005 | 07:23 PM
accordisslow's Avatar
replace your ETC Switch i had the same problem.
Old Dec 31, 2005 | 09:21 PM
fixitman's Avatar
Default Re: 98 honda accord, coolant fans are not working (accordisslow)
what is the etc switch and where is it located
