90 Accord Tachometer problem
Old Dec 31, 2005 | 10:16 AM
flatthead's Avatar
Default 90 Accord Tachometer problem
Hey all:
I've got a 90 Accord that had a battery positive lead that was corroaded pretty bad. As a result, the car had some electrical issues until I fixed the lead and terminal.
One of the weird things was when I tried to start the car, the tach would go from 0 clockwise to past redline, even with the motor not running. Now, it just stays there in this pegged position. Is there a way I can reset the tachometer?
Thanks
Jim
flatthead@charter.net
Old Dec 31, 2005 | 01:41 PM
hondadude's Avatar
Default Re: 90 Accord Tachometer problem (flatthead)
Sounds like you'll need to remove the cluster then pop off the plastic cover and move the needle back to it's home position.
tykraus7
Feb 1, 2010 04:02 PM
flatthead
Jan 2, 2006 07:52 PM
flatthead
Jan 1, 2006 07:00 PM
