bad bearing, cv joint, ball joint or ??????
Hi there, i am having some problems with my 89 crx si. When I pass 30 mph, a weird sound starts..... Its like my tire's where half metal and half ruber loool.... and when I make a turn, the noise is bigger. I doubt is the cv joint because when I make a turn at low speed, they dont sound..
I think it might be bad bearings (hub) but I dont know........
the car runs fine, good engine and good tranny...
could it be bad cv joint ? or ball joint ? or something else ?
thanks for the help ppl....
most likely a wheel bearing. if u dont have access to a lift put ur car up on jackstands and have someone take it up to around 40mph. then take a long screwdriver or something and hold one end to the spindle and the other to ur ear. u will be able to tell instantly if its a bearing. that will help u locate which side is bad. if only one is bad its not a bad idea just to do both.
thanks, I searched for the wheelbearing to see a picture of it but didnt had any luck.... can you buy the bearing or do you need to buy the hub assembly ?
and another thing, where can I get them ?
thanks
thanks
I'm pretty sure you can buy just the bearing, however it will need to be pressed out/in. When mine went I just went to a junkyard and swapped the whole hub. $10 and no pressing.
Majestic only lists the whole hub. Maybe autozone or similar woudl have them.
ok i can tell you the easy way , jack the car up and grab the tire at 6 ,12 o clock. then push with one hand and pull with the other and see if you can move it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pakipr »</TD></TR><TR><TD CLASS="quote">
LOL
but all jokes aside its the wheel bearing most likely
LOL
could very well be wheel bearings. these tend to go out w/ age/time/abuse.
depending on what you consider noise, many of us had problems w/ steering rack bushings. it is most pronounced when turnign right, but does NOT sound like metal on metal.
while you're in there doing a wheel bearing, it's a good time to replace the steering rack bushing and check all your ball joints since everything will be apart anyways.
good luck!
good luck!
Imprezor
Jul 23, 2012 08:37 AM
90babyblue
Jun 20, 2004 04:27 PM
