need help bad with my axels
i hav a jdm sohc zc swap and i am using crx si axels, iam putting it in a 1988 crx hf theproblem is the axels dont bolt up to the hub so i went to a shop and had them taken aprt to switch the end splines, the main issue is the splines have differnet cages, so is there any way to switch the hf splines to the si axels with out geeting custom axels if any body can help me u are the man
that was an option but cant find any and that would take too longany other options<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ryan89crx »</TD></TR><TR><TD CLASS="quote">get dx or si hubs/knuckles if you are using anything other than HF axles</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ryan89crx »</TD></TR><TR><TD CLASS="quote">just use your HF axles then, they will work fine in the tranny and the hub</TD></TR></TABLE>
i tried that it didnt work dont know y i think cuz the hf axels hav 23 splines or something like that and the si axels hav m
ore splines
ore splines
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kantfadedisazn »</TD></TR><TR><TD CLASS="quote">i tried that it didnt work dont know y i think cuz the hf axels hav 23 splines or something like that and the si axels hav m
ore splines</TD></TR></TABLE>actually, as long as your tranny doesnt require an intermediate shaft, then yes it will work. all 88-91 axles share the same tranny splines, dx ans si share the same hub splines while hf have different hub splines.
so any hf/dx/si axle will spline with the tranny, but the hf is the only one that will spline with the hf hub.
ore splines</TD></TR></TABLE>actually, as long as your tranny doesnt require an intermediate shaft, then yes it will work. all 88-91 axles share the same tranny splines, dx ans si share the same hub splines while hf have different hub splines.so any hf/dx/si axle will spline with the tranny, but the hf is the only one that will spline with the hf hub.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ryan89crx »</TD></TR><TR><TD CLASS="quote">actually, as long as your tranny doesnt require an intermediate shaft, then yes it will work. all 88-91 axles share the same tranny splines, dx ans si share the same hub splines while hf have different hub splines.
so any hf/dx/si axle will spline with the tranny, but the hf is the only one that will spline with the hf hub.</TD></TR></TABLE>
yeah see that is where i am screwed the tranny does hav an intermediate shaft so i guess i am screwed
nevermind i just got in contact with a buddy of mine and he has two si hubs he is going to sell me for 75 bucks for both, but thanks for the help
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kantfadedisazn »</TD></TR><TR><TD CLASS="quote">yeah see that is where i am screwed the tranny does hav an intermediate shaft so i guess i am screwed
</TD></TR></TABLE>if you have an intermediate shaft, and si hubs, you will use 90-93 integra axles
