h22 bogging @ low rpm
i have a 94 jdm h22 in a 93 cx hatch, @ low rpm's my car bogs out and feels like it wants to die, what is causing this...i am running a chipped p28 ecu although i have tried running a stock p13 and its even worse
Try to adjust your idle a little up.
You have a chipped p28 - so you might have to use the mnii bolt under the throttle.
I have the s300 so, its all a click of the button with me. Mine used to do it, but I adjusted my idle up to 950 and it doesn't bog anymore.
But I also disabled my o2 sensor so, that is also a possibility.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vietboiracer0 »</TD></TR><TR><TD CLASS="quote">o2 sensor</TD></TR></TABLE>
can someone explain this
jerryscherry
Engine Management and Tuning
Dec 24, 2010 04:13 PM
fabe85
Jun 7, 2007 05:51 AM
