CR-X H22 Forbidden S.S. ?
Old Dec 30, 2005 | 11:25 PM
SoClose's Avatar
Default CR-X H22 Forbidden S.S. ?
Hi, of course i have a h22 in my crx as the title says . . . im wanting to know if a forbidden short shifter would bolt on correctly with out any heavily modifications . . anybody tried this or actually know 100% sure if its been done or not . . then again its a H22 in a CRX. http://www.ForbiddenMotorSports.com
thanks . .
Old Dec 31, 2005 | 06:55 AM
kasso's Avatar
when you did the swap, which shifter did you use? if you used the crx one, get a crx short throw, if its the accord/prelude one, use the one for accords/preludes.
Old Dec 31, 2005 | 07:00 AM
nblkid's Avatar
Default Re: (kasso)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kasso &raquo;</TD></TR><TR><TD CLASS="quote">when you did the swap, which shifter did you use? if you used the crx one, get a crx short throw, if its the accord/prelude one, use the one for accords/preludes.</TD></TR></TABLE>
Old Dec 31, 2005 | 08:36 AM
ExplicitSpeed360's Avatar
Banned.
Default Re: (nblkid)
I believe accord shifters are shorter then the prelude and less bulky then the prelude if I remember right. The accord cables were just the right size too! 90-93. I am interested in these shifters too but dont think it will help too much on cable shifters.
Modified by ExplicitSpeed360 at 10:15 AM 12/31/2005
Old Dec 31, 2005 | 02:01 PM
SoClose's Avatar
Im using a prelude shifter right now . . its hitting the shifter frame when i put it in 5th and Reverse really annoying thats why my shift boot and console is stripped . .
Old Dec 31, 2005 | 06:10 PM
Banned.
Default Re: (S o C l o s e)
I mounted mine beneath so I could retain the console and stock look. It takes a little bit of doing to line things up and test fit so everything is straight but will be worth it in the end.
SkRiBLaH
Apr 22, 2008 01:26 PM
deuces
Feb 24, 2007 03:48 PM
Freeltec
Apr 19, 2006 08:15 PM
jdmcivicferio
Feb 25, 2003 08:30 PM
