motor mount help
From: if you build it they will come, the bottom carolina, duh
i am in the process of my engine swap and was wondering if i could use the 90-93 tranny mount for my b16 swap into a crx si, this is just temporary until i get my new set of mounts in.
thanks in advance
thanks in advance
i have 2 avid motor mounts and the tranny one got alittle bent from a car accident, so i was just seeing if i would be able to use the da 1 for a couple of days, hopefully.
i believe that that mount is too short, all of the EF b mounts seem to have a little longer piece than the integra b mounts. i could be wrong but maybe you should look at the pics and see what i mean.(not that i have any to post)
u would think they would ,not sure, sense you use everything else from the da teg, and b/c the motor sit pretty much in the same position
but thanks for you opinion
still lookin for an answer
[626]95-GSR
Nov 20, 2005 09:15 AM
