Mini-Me with ZC block... has it been done?
Old Dec 30, 2005 | 09:02 PM
xxmikexx206's Avatar
Default Mini-Me with ZC block... has it been done?
Hey everyone, I am currently getting ready to do a "Mini-Me" swap to my 90' CRX, BUT... I'm going to use a SOHC ZC block which is what I currently have, I know that the compression ratio is going to be a bit higher, but I know it can be done... Anyway I have everything I need and am going to do the swap this Sunday the 1st!!!! I am using a 93' Del Sol Si head, my question is has this swap ever been done and was there any complications, specifically with the compression ratio???? All opinions are welcomed and appreciated... thanx.
-Mike
Old Dec 30, 2005 | 09:16 PM
pandarex's Avatar
Default Re: Mini-Me with ZC block... has it been done? (xxmikexx206)
its been done, as far as i know, it would be the same complications you might get from a rergualr mini-me. honda tuning covered a mini-me swap but i lost the magazine, the zc with the y8 had the highest CR then the zc wiht the z6. i dont believe you will have any wierd problems with it, good luck
Old Dec 30, 2005 | 09:22 PM
Default Re: Mini-Me with ZC block... has it been done? (hondazc89)
awesome... thats good to know from someone else, I'm usually doing all the swaps to my buddies cars, and never get around to working on my own, this is a small project and a good days work but I can honostly say the first project for MY OWN car... the main thing I was worried about was the c.r. because I didn't want to end up having to use trick fuel... thanx for the info
88 Si
Mar 25, 2025 05:27 AM
B18C1_CRX
Jul 10, 2006 12:09 AM
EF9 JAMS!!!
Dec 21, 2004 10:52 AM
junkyardRx
Apr 15, 2004 12:53 PM
