dyno results
Old Dec 30, 2005 | 08:02 PM
SpoolnEG6's Avatar
Default dyno results
First of all sorry no graph yet. But got the R dyoned today and it put down 183whp/129wtq. Done on a Mustang dyno
Mods:
Password JDM CF intake
DC sports 4-2-1 header
Buddy Club Pro spec
My goal is 200whp with stock bottom end, so now what to do? I know I need a better header and cams (probably going with BC 3+) and what else?
Modified by SpoolnEG6 at 12:17 AM 12/31/2005
Modified by SpoolnEG6 at 8:33 AM 12/31/2005
Modified by SpoolnEG6 at 9:24 AM 12/31/2005
Old Dec 30, 2005 | 08:51 PM
djSALIX's Avatar
Default Re: dyno results (SpoolnEG6)
A good tune.
Valves, springs, & retainers.
Possibly an intake manifold?
Old Dec 30, 2005 | 08:54 PM
SpoolnEG6's Avatar
Default Re: dyno results (djSALIX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djSALIX &raquo;</TD></TR><TR><TD CLASS="quote">A good tune.</TD></TR></TABLE>
yeh i forgot to add ill be getting an AEM EMS most likely.
Old Dec 30, 2005 | 10:03 PM
DvD3's Avatar
B A N N E D
Default Re: dyno results (neo_)
cams, valve springs, valves, retainers, intake manifold, take the cat out or get an aftermarket one.
good tune, as u said aem ems.
Old Dec 30, 2005 | 10:25 PM
white rocket's Avatar
With aftermarket cams you will need a valvetrain upgrade as well depending on which ones you go with. A higher end header may net a few more ponies but nothing drastic. After a GOOD TUNE with the EMS you mentioned you should be close to 200whp.
183whp with just those mods seems really good
Personally I wanted to be in the 200whp club with completely stock internals. I've given up on that dream
Old Dec 30, 2005 | 11:00 PM
Haleiwa-Brando's Avatar
Default Re: dyno results (white rocket)
I'd say ditch the header for something better. (Rhyme = 5 points)
There is a ton of untapped power just waiting in the head. If your goal as you said is to keep the bottom end completely stock, then get head work done, followed up with aftermarket cams/valvetrain/cam gears. Not only will you make more power, but you will in essence have an efficiently better engine.
Old Dec 31, 2005 | 04:34 AM
SpoolnEG6's Avatar
Default Re: dyno results (Haleiwa-Brando)
I'm still up in the air as to what cams i am getting. I was looking into the buddy club 3+ but i need to do alot more searching as to which are going to be best. I was also considering the Rocket Motorsports product as well
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by neo_ &raquo;</TD></TR><TR><TD CLASS="quote">Some higher compresion pistions </TD></TR></TABLE>
I want to keep stock bottom end
Modified by SpoolnEG6 at 9:11 AM 12/31/2005
Old Dec 31, 2005 | 05:20 AM
Bbasso's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by white rocket &raquo;</TD></TR><TR><TD CLASS="quote">
Seems too good...
Hey, best of luck getting to 200whp.
Old Dec 31, 2005 | 05:23 AM
SpoolnEG6's Avatar
Default Re: dyno results (Bbasso)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bbasso &raquo;</TD></TR><TR><TD CLASS="quote">
Seems too good...
Hey, best of luck getting to 200whp.</TD></TR></TABLE>
I'm going to try to get the graph up this weekend if 2nite doesnt kill me
I was also very suprised with the numbers. I was hoping for around 175ish. This dyno was tuned to be exact with a dyanpack. Example, and escort they use for testing the dyno put down 109 on the dynapack they used to have and 109 on the mustang dyno they have now.
Hoping to have my 200whp by time the Expo hits
Old Dec 31, 2005 | 05:59 AM
vtec.dc2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpoolnEG6 &raquo;</TD></TR><TR><TD CLASS="quote">First of all sorry no graph yet. But got the R dyoned today and it put down 183whp/129wtq. Done on a Mustang dyno
Mods:
Buddy Club Pro spec
Modified by SpoolnEG6 at 9:24 AM 12/31/2005</TD></TR></TABLE>
is that SAE corrected numbers?
Old Dec 31, 2005 | 06:03 AM
SpoolnEG6's Avatar
Default Re: dyno results (vtec.dc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec.dc2 &raquo;</TD></TR><TR><TD CLASS="quote">
is that SAE corrected numbers?</TD></TR></TABLE>
yup...like i said i was suprised with the numbers as well
Old Dec 31, 2005 | 06:55 AM
ChicagoMike's Avatar
Good luck with your build, nice numbers. I'm trying for the 200whp mark also. Right now i'm at 196whp and 131tq.
1998 ITR swap
S2S1 cams
Dented up DC 4-1 header
RC 440 injectors (I know their a little big)
Tuned with Hondata
Old Dec 31, 2005 | 06:57 AM
SpoolnEG6's Avatar
Default Re: (RippinVTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RippinVTEC &raquo;</TD></TR><TR><TD CLASS="quote">Good luck with your build, nice numbers. I'm trying for the 200whp mark also. Right now i'm at 196whp and 131tq.
1998 ITR swap
S2S1 cams
Tuned with Hondata</TD></TR></TABLE>
how were the gains from the cams? Im trying to decide what i want, the buddy club's looked good but i think they might be too mild for me to reach my goal.
What intake are you running? On the butt dyno the password cf intake made a good deal of mid range compared to the DAC that was on there.
Old Dec 31, 2005 | 07:08 AM
My intake is a short ram (no namer)
All fuel, cams, and tuning got done at once
Went from 161whp to 196whp
TQ didn't move a whole lot 128tq to 131tq
With a real header I should break 200
Old Jan 2, 2006 | 08:10 AM
digital sol's Avatar
you went from 161whp to 196whp just from cams and tuning?
what cam's?
stock valvetain?
My goal is also 200whp, ive been told that Rm valvetrain with jun 3's and some cam gears will get me there, but you seem to have hit around my goal is alot fewer mod's.
Old Jan 2, 2006 | 08:29 AM
MI KENT's Avatar
check out some of red civic standard's posts:
https://honda-tech.com/zerothread?id=1425934
dc2-slow
18
Jan 19, 2008 12:43 PM
BABY NSX
43
Jun 14, 2007 10:14 AM
athoughts
29
Feb 10, 2005 05:01 PM
kwik93si
Jul 8, 2003 11:37 AM
Captain Save-a-Hoe
Apr 4, 2003 01:17 PM
