crx throttle position sensor?
Old Dec 30, 2005 | 07:24 PM
rexless_wreck's Avatar
Default crx throttle position sensor?
Well im about to buy a crx with a b16a and it has a few problems. the car has a problem idling and it bounces from 800-2000 rpms and the ecu is giving off a check engine light code 6. and the some electrical stuff doesn't work such as the cd player and brake lights. any idea of what maybe wrong and what it needs to be repaired?
Old Dec 30, 2005 | 07:33 PM
ArtyG's Avatar
Default Re: crx throttle position sensor? (rexless_wreck)
Idle problem may be as simple as checking the grounds. We had that happen recently on a Civic we did a swap on, and it was just two loose grounds.
Old Dec 31, 2005 | 08:43 AM
ohhh...thanks ill look into that
9d2blkDA
Aug 3, 2013 04:06 PM
g wheel
Aug 22, 2009 08:14 AM
pearsonhondatech
Apr 12, 2009 09:54 PM
KSE-CRX
Jun 12, 2008 09:24 AM
ungcobob
Jan 18, 2007 11:54 AM
