ZC trans 2 piece axle?
Old Dec 30, 2005 | 06:08 PM
thapimpfromchi's Avatar
Default ZC trans 2 piece axle?
Sup guys. I had a zc motor and trans in my ef. I blew the motor. I picked up a 92-95 dx motor from a kid on here. i noticed on the zc there is a 2 piece driver side axle. the part that bolts to the motor on the zc doesnt have a place to bolt up to on the dx. do i need to use the 2 piece? i have spare axles from a 90 dx that i can use if they'd fit. anyone know? thanks.
Old Dec 30, 2005 | 06:11 PM
d16vtecx's Avatar
Default Re: ZC trans 2 piece axle? (thapimpfromchi)
only the short dx axle will fit
Old Dec 30, 2005 | 06:27 PM
Default Re: ZC trans 2 piece axle? (d16vtecx)
what do u mean? what would i have to use for the long one then?
Old Dec 30, 2005 | 07:08 PM
d357r0y's Avatar
On the back of your block should be 3 spots where holes could be drilled/tapped to accept the ZC intermediate shaft.
Old Dec 30, 2005 | 07:20 PM
Default Re: ZC trans 2 piece axle? (d357r0y)
hmm, i thought of that too, but if u look at the block, it doesnt have like a raised spot where i can drill. there the bolt goes on the zc, its recessed on the dx. ill take pics tomorrow and post them if i have to. i was just hoping someone had done this kind of thing before.
Old Dec 30, 2005 | 09:29 PM
jlicrx's Avatar
the holes are recessed on the ZC block also - the bolts have a shoulder on them that fits in the recess
Old Dec 30, 2005 | 10:48 PM
downest's Avatar
Default Re: ZC trans 2 piece axle? (jlicrx)
Why are you going from a ZC to a DX motor? A6's are cheap man, and you dont need anything extra with it, it will all swap over. Did you have a SOHC or DOHC? If you had a SOHC it would be basically the same thing if you found an A6.
Old Dec 31, 2005 | 12:19 AM
Default Re: ZC trans 2 piece axle? (downest)
i blew my zc motor and i just needed something to get me by. I had a dohc-zc. i guess i'll have to show u pics of the bolt holes i was talkin about. maybe i'm just not seeing it the right way. ill have some up tomorrow. thanks for all the help so far
Old Dec 31, 2005 | 12:45 AM
court's Avatar
25 Year Member
sent u pm
Old Dec 31, 2005 | 08:48 AM
Default Re: ZC trans 2 piece axle? (court)
Pm replied. Here are those pics i was talking about. hope this will help clear stuff up.
That is the ZC block, notice the three bolt holes for the 2-piece axle.
There is the shaft being put up to the block.
DX motor. only one hole.
again the axle up to the block. notice no where for the other holes to line up.
this is what i was referring to when i said the zc block had a raised spot for the bolt holes.
and this is the dx, without the raised area.
well, with all those pics, anyone have any suggestions?
Old Dec 31, 2005 | 08:49 AM
holy crap. sorry, i didnt realize those would be so large. but u get the idea.
Old Dec 31, 2005 | 12:11 PM
bump
Old Dec 31, 2005 | 12:14 PM
TH33G4MON3's Avatar
I had the inter. shaft on my zc never took it off or tried anything different nice and easy
Old Dec 31, 2005 | 12:16 PM
Default Re: ZC trans 2 piece axle? (TH33G4MON3)
well im swapping motors. thats what this is about.
Old Dec 31, 2005 | 12:26 PM
1point7db2's Avatar
You may have to get a trans that does not accept an intermediate shaft, ie: si, dx, and use a long drivers side axle.
Old Dec 31, 2005 | 02:21 PM
Sikocivic's Avatar
Default Re: ZC trans 2 piece axle? (blownEG93)
You can swap a Si or DX final drive into the ZC tranny and then use the Si or DX axles. Othewise you need a tranny swap too.
Old Jan 3, 2006 | 11:15 AM
elchapin's Avatar
thapimpfromchi can you call me please 773-269-0364 erik I want to buy your car. thanks
Old Jan 5, 2006 | 10:37 PM
Default Re: (elchapin)
hey elchapin, ill get u some pics tomorrow. i've been really busy. sorry for the delay.
LowAndSlowEF
Jan 13, 2012 07:58 AM
r1ch1e
Apr 4, 2006 11:59 AM
86CRXSi
Jun 11, 2002 04:11 PM
badazzrex
Jan 29, 2002 06:17 PM
