Suspension & Brakes Theory, alignment, spring rates....
ASR reinforcement brace and CTR sway will it work?
Old Dec 30, 2005 | 06:03 PM
Treblarefils's Avatar
Default ASR reinforcement brace and CTR sway will it work?
Just looking for confirmation that the CTR 22mm sway bar and the ASR brace will work together. Hope so because its on its way..This is going on 2000 Si.
Update yeah it works here it is..
Modified by Treblarefils at 5:29 PM 1/15/2006
Old Dec 30, 2005 | 09:37 PM
EeeJayEight's Avatar
Default Re: ASR reinforcement brace and CTR sway will it work? (Treblarefils)
from what i understand..
the asr kit is made to work with the ITR bar...
now the only difference between the 96 JDM itr bar (22mm), us ITR bar(22mm) and CTR bar is the bushings where the endlinks attach...
asr provides you with metal spaces to adapt the endlinks...
can anyone confirm this?
Old Dec 30, 2005 | 10:03 PM
Default Re: ASR reinforcement brace and CTR sway will it work? (EeeJayEight)
yeah it says it will work with a variety of bars so i hope it will work or ill be getting the itr bar i guess..
Old Dec 30, 2005 | 11:50 PM
contact the dudes from aspec...
http://www.a-spec-racing.com
they have been real helpful for me over AIM
Old Dec 31, 2005 | 12:34 AM
emailed many times they never respond. Maybe i should try AIM then.
Old Dec 31, 2005 | 01:58 AM
alwaysoverkill's Avatar
22mm is 22mm so i don't see how it wouldn't work. CTR and ITR 22mm rear sway bars both fit EK's so i'm under the impression they are identical anyways. I'm ordering the ASR brace and I have a 22mm CTR rear sway bar, while i'm sure Charleston will confirm this, i'm not expecting any problems with my CTR bar fitting.
Charleston responded very fast when I IM'd him, try again.
Old Dec 31, 2005 | 10:27 AM
Default Re: (alwaysoverkill)
guys at pitcrew were pretty helpful.. informed me charleston was out of the country or something... but anyway...
it will work.. the only difference that i have heard of is that the OEM bushings are different thus being the reason for asr providing metal supplements for the itr bar
Old Jan 1, 2006 | 04:12 PM
It's made of 6061 T-6 aluminum. So far it's only made for the EK and it compatible with the CTR, mugen 22mm and ITR rear bars. There is still no application for the EG yet.
Regards,
Charleston
Found in an old thread...
https://honda-tech.com/zerothread?id=785497
Old Jan 1, 2006 | 04:32 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Treblarefils &raquo;</TD></TR><TR><TD CLASS="quote">It's made of 6061 T-6 aluminum. So far it's only made for the EK and it compatible with the CTR, mugen 22mm and ITR rear bars. There is still no application for the EG yet.
Regards,
Charleston
there you go!! for searching
Old Jan 1, 2006 | 05:29 PM
Yes but i searched for 3 days straight lol so much info i had to sort through what i didnt need.
Kennyjai
Jun 22, 2012 09:36 AM
Naterror
Suspension & Brakes
Sep 2, 2006 11:53 AM
r1de4life
Apr 29, 2006 03:27 AM
saveacivic
Suspension & Brakes
Apr 15, 2006 12:31 AM
hazard_one
Jan 7, 2004 10:43 AM
