aem cam gear settings?
Old Dec 30, 2005 | 04:27 PM
EK-SI's Avatar
Default aem cam gear settings?
anyone had any dyno time with b-16 adjusting the cam gears. i have a 99 si naturally aspirated with just bolt ons. and i was wondering if anyone knows how i should set my cam gears to make a little more. so if anyone has done any dyno tuning and knows how i should set them let me know please.
Old Dec 30, 2005 | 04:30 PM
wob's Avatar
wob
Default Re: aem cam gear settings? (EK-SI)
every motor is different.. go get a tune.. if ur stock.. dont bother right now
Old Dec 30, 2005 | 04:34 PM
EK-SI's Avatar
Default Re: aem cam gear settings? (wob)
im far from stock but i dont have money to spend on dynoing. i have intake header testpipe catback itr throttle body and itr manifold itr ecu itr trans itr cams underdrive pulleys.
Old Dec 30, 2005 | 04:36 PM
2k.civic.si's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EK-SI &raquo;</TD></TR><TR><TD CLASS="quote">im far from stock but i dont have money to spend on dynoing. i have intake header testpipe catback itr throttle body and itr manifold itr ecu itr trans itr cams underdrive pulleys.</TD></TR></TABLE>
if thats all you have done the motor internally is stock..leave the cam gears at 0
Old Dec 30, 2005 | 04:41 PM
EK-SI's Avatar
Default Re: aem cam gear settings? (2k.civic.si)
if im gonna set them at 0 then theres no ******* point in putting them on
Old Dec 30, 2005 | 04:44 PM
wob's Avatar
wob
u could always cut the timing cover, or valve cover and add to the bling factor....
Old Dec 30, 2005 | 04:47 PM
EK-SI's Avatar
im not cutting my valve cover one because i had it powder coated red and two because thats gay
Old Dec 30, 2005 | 04:50 PM
germz's Avatar
heres my set-up w/ aem cam gears.
JDM B16a SiR-II obd-1
Milled Head
Skunk2 Stage 1 Camshaft
Skunk2 Ti Dual Valve Springs
Valves Adjusted
AEM Cam Gears I+2 E-1
B&M FPR w/ Gauge (41psi)
AEM CAI w/ Bypass Valve
Bosch Platinum +4 plugs
Onsoku 9.5 mm wires
Stock Block
JDM ITR Header 4-1 w/ 2.5 collector
made 165whp/113wtrq@8700rpm
Chipped P28 tuned Uberdata
Old Dec 30, 2005 | 04:53 PM
wob's Avatar
wob
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EK-SI &raquo;</TD></TR><TR><TD CLASS="quote">im not cutting my valve cover one because i had it powder coated red and two because thats gay</TD></TR></TABLE>
its actually not gay if it serves a function... i u ever owned a boosted d-series and paid for dyno time.. u would understand that it saves alot of time and money having the cut out.. since u hafta pull the valve cover off just to get the timing cover off ne way..nothing homo erotic about that...
Old Dec 30, 2005 | 04:57 PM
Kamin's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EK-SI &raquo;</TD></TR><TR><TD CLASS="quote">if im gonna set them at 0 then theres no ******* point in putting them on</TD></TR></TABLE>
well if your not gonna have them tuned on a dyno theres no ******* point having them eithre
stop being a cheapass, spend the money to dyno or dont use them. blindly adjusting your cam timing will not do you any good.
Old Dec 30, 2005 | 06:53 PM
Padawan's Avatar
Darth ModerVader
Default Re: aem cam gear settings? (Kamin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kamin &raquo;</TD></TR><TR><TD CLASS="quote">well if your not gonna have them tuned on a dyno theres no point having them eithre
stop being cheap, spend the money to dyno or dont use them. blindly adjusting your cam timing will not do you any good. </TD></TR></TABLE>
I concur.
Old Dec 30, 2005 | 07:57 PM
2000EM1's Avatar
stop being a cheapass, spend the money to dyno or dont use them. blindly adjusting your cam timing will not do you any good. </TD></TR></TABLE>
werd. werd. and werd.
Old Dec 30, 2005 | 09:32 PM
chairwitharmrests's Avatar
Default Re: aem cam gear settings? (2000EM1)
EXAAAAACTLY, retard
GAY retard, x2, supersized , every body watch out his valve cover was powder coated red.
I cant belive you've gotten this far with car, oh ya wait its not far, especially not far enough to need CAM GEARS!!!!!!!!!
JDMkidGSR
Jul 27, 2006 05:18 PM
jt-sport
Jun 21, 2004 08:58 PM
PoW3l2BaN
Jan 30, 2003 11:58 AM
Maximo
Jun 5, 2002 07:58 AM
