Picked up a 93 LX today.
Old Dec 30, 2005 | 03:44 PM
92ehatch's Avatar
Default Picked up a 93 LX today.
well i got in a wreck with my civic and had to get a new car before my rental ran out. (other persons insurance would only cover a rental for 1 week)
being hard pressed for time i bough this 93 accord lx sedan.
seemed clean, ran really good. however....i got home and decided to check a few things i forgot to check in my rush to get the car before the tag office closed.
#1. air filter was torn in half, part was in the box, the other part was stuck up againts the TB.
im glad i was able to get to that before it got stuck FT...think any damage may have been caused by this?
#2. oil all over plugs and plug wires.
bought new valve cover gasket kit (includes all seals), can oil in there cause any major problems?
#3. popping when puttong on brakes...what can cause that?
Old Dec 30, 2005 | 06:27 PM
BLKFLSH's Avatar
Default Re: Picked up a 93 LX today. (93egsedan)
Yes oil in the sparkplug tubes will become a problem. When it gets high enough it will start to short the plug out (run real bad). Then if you don't get the oil out first, it will go into the cylinder when you remove the sparkplug (you can blow the oil out with air, if you don't have air what I did was tape a small vacumme hose to a shopvac and sucked it out), this will work until you can change the seals. If you got some o-rings with the gasket kit they are for under the rockerarm assembly. Here is a link describing the process. It includes resetting valves. If you have any more questions on this subject, let me know.
http://www.cb7tuner.com/vbb/sh...+tube
Old Dec 31, 2005 | 05:33 AM
92ehatch's Avatar
Default Re: Picked up a 93 LX today. (BLKFLSH)
kool man. thanks.
i got up early to start reading now i have something to read
Old Dec 31, 2005 | 06:11 AM
P_Adams's Avatar
If you're committed to doing the majority of repairs and upgrades yourself; I would strongly recommend you getting a Service Manual.
Popular publishers are
Helm Publications (supplies many OEM Manufacturers)
Chilton
Haynes
Not only will they guide you through procedures, but will also give you insight as to how everything works together
P
Modified by P_Adams at 3:44 PM 12/31/2005
Old Dec 31, 2005 | 06:35 AM
92ehatch's Avatar
Default Re: Picked up a 93 LX today. (P_Adams)
yeah. trying to find one
Old Dec 31, 2005 | 06:43 AM
P_Adams's Avatar
Helm Publications:
http://www.helminc.com/helm/ho...earch
Chilton's Publications:
http://wwwchiltonsonline.com
Haynes Publications:
http://www.haynes.com/
Or one-stop shopping:
http://www.repairmanual.com/
P
Old Dec 31, 2005 | 03:59 PM
92ehatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P_Adams &raquo;</TD></TR><TR><TD CLASS="quote">Helm Publications:
P</TD></TR></TABLE>
yeah, im a pirate, but so far no go, so ill wait till i get paid and buy the helms of course....but im gonna use teh EBAY for lower price..or HT classifieds
however, can anyone answer the question about the popping noise when i hit my brakes?
it happens on the front left. doesnt do it during turns, only when i hit brakes? still CV's?
Old Dec 31, 2005 | 04:31 PM
92ehatch's Avatar
oil is also coming out of the PCV valve onto the valve cover. argggg
Old Dec 31, 2005 | 07:12 PM
hondadude's Avatar
You might have a radius rod that the nut has backed off and it's moving in the subframe...My best guess
Old Dec 31, 2005 | 10:03 PM
92ehatch's Avatar
Default Re: Picked up a 93 LX today. (hondadude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondadude &raquo;</TD></TR><TR><TD CLASS="quote">You might have a radius rod that the nut has backed off and it's moving in the subframe...My best guess</TD></TR></TABLE>
i dont even know what that is...
im gonna lift it up and take a look at everything here soon.
happy new year anyways
Old Jan 1, 2006 | 08:58 PM
92ehatch's Avatar
looked closer today and it appears that my PCV valve has a leak around it.
i already got the gaskets for the valvecover and tubes and ****, but i was wandering, could a faulty pcv valve caused this to begin with?
should i just replace the PCV valve grommet or both grommet and PCV valve. and, is the autozone/advance PCV valve good, or should i get a honda oem (im kinda poor)
Jessica.t
Mar 9, 2016 08:16 PM
dfJDM
Jan 18, 2011 11:14 PM
kuhz626
Jan 11, 2008 04:48 AM
Metalmat
Feb 11, 2007 07:28 PM
jefe
24
Nov 18, 2005 01:06 PM
