Car wont start
First thing you need to do is check for spark, fuel, timing, and then compression. Also, make sure you have the sparkplug wires in the right order and that you have all the grounds attached.
Alrght... the starter works now, it's catching the flywheel.. just wont turn over. It's not getting fuel, and I don't believe it's getting spark. Can I have any grounds whatsoever off the car? All grounds in engine bay are fine. Thanks in advance.
Pull out the main relay and look for cracks in the solder. Usually if the main relay goes it will start intermittently. Make sure your gas cap is all the way on too.
