Question about ITB
Old Dec 30, 2005 | 01:14 PM
whiskeydicks45's Avatar
Default Question about ITB
Would it do any good if on ITB you extended it so that it came out of the hood and faced forward so that you get the forced induction affect??? just curios it was something I thaught about last night. Thanks for you thaughts
Old Dec 30, 2005 | 01:23 PM
Default Re: Question about ITB (whiskeydicks45)
so all of a sudden i seem to get no response when i talk about jdmcivic forum it only takes about 5 secounds to get some jackass to give his rude remark though
Old Dec 30, 2005 | 01:24 PM
tallyturbo's Avatar
lets just say it would be unique looking
Old Dec 30, 2005 | 01:52 PM
come on you guys just a little input
Old Dec 30, 2005 | 02:05 PM
JDMlyfestyle's Avatar
i was gonna put a Sti Hood scoop on my car when i was going to run my ITB setup
Old Dec 30, 2005 | 02:10 PM
Civicse's Avatar
i don't think it would do anything, you would have to have longer tubing and a bend, which would constrict the flow.
Old Dec 30, 2005 | 02:11 PM
Default Re: Question about ITB (Civicse)
but if you had air being forced down the bend that wouldnt help at all??
Old Dec 30, 2005 | 02:17 PM
temp's Avatar
Default Re: (JDMlyfestyle)
doing ITB requires finesse, sometimes she will say no, but she is curious....ITB can be fun if she doesnt seize up
Old Dec 30, 2005 | 02:21 PM
AnToNy's Avatar
Default Re: (temp)
^^^no thats IDB
I don't think its a good idea. Just tilt your hood, or get a different one.
Old Dec 30, 2005 | 02:25 PM
Default Re: (temp)
what would cause the engine to seize up??
Old Dec 30, 2005 | 02:26 PM
temp's Avatar
Default Re: (AnToNy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AnToNy &raquo;</TD></TR><TR><TD CLASS="quote">^^^no thats IDB
I don't think its a good idea. Just tilt your hood, or get a different one.</TD></TR></TABLE>
IDB being the "slang" way to say it
AnToNy's Avatar
Default Re: (whiskeydicks45)
water= hydrolock
Old Dec 30, 2005 | 02:27 PM
temp's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whiskeydicks45 &raquo;</TD></TR><TR><TD CLASS="quote">what would cause the engine to seize up??</TD></TR></TABLE>
OMFG AHAHAHAHAHAHAHAHHHAHAHAHAHAHAHAHAHAHAHAH
Old Dec 30, 2005 | 02:32 PM
EJAYATE's Avatar
I Deliver
Get a k swap, then you will have no bend!
Old Dec 30, 2005 | 02:34 PM
AnToNy's Avatar
Default Re: (B2CivMan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2CivMan &raquo;</TD></TR><TR><TD CLASS="quote">Get a k swap, then you will have no bend!</TD></TR></TABLE>
WE GOT A WINNA!!!
Old Dec 30, 2005 | 02:35 PM
Default Re: (temp)
does anybody know what temp's problem is
Why is it that I can't post on any of these honda forums without someone being an A**
Old Dec 30, 2005 | 02:37 PM
Ok lets say I did have a K swap and it wasn't raining would there be any benefit from having the IDB's extend out so that it would give the forced induction effect??
Old Dec 30, 2005 | 02:40 PM
EJAYATE's Avatar
I Deliver
No one is being one, we just told you what would probably happen. It's very impractical, unless you have and engine with the intake manifold on the front side such as a k-series engine. Even thenn the only time i've seen itb's through the hood was on dedicated track cars.
Old Dec 30, 2005 | 02:42 PM
temp's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whiskeydicks45 &raquo;</TD></TR><TR><TD CLASS="quote">does anybody know what temp's problem is
Why is it that I can't post on any of these honda forums without someone being an A**</TD></TR></TABLE>
your problem is you don't think. Second of all, on a b-series motor if you had CURVED tubes on your velocity stacks you would have a SHITLOAD of turbulent air running into the throttle bodies because they would have to follow bends which would cause a loss in power. now you sir can kindly go expletive yourself.
temp's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2CivMan &raquo;</TD></TR><TR><TD CLASS="quote">No one is being one, we just told you what would probably happen. It's very impractical, unless you have and engine with the intake manifold on the front side such as a k-series engine. Even thenn the only time i've seen itb's through the hood was on dedicated track cars. </TD></TR></TABLE>
hahaha i find it funny that only one person on here got what i was saying
Old Dec 30, 2005 | 02:43 PM
z6's Avatar
z6
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whiskeydicks45 &raquo;</TD></TR><TR><TD CLASS="quote">Would it do any good if on ITB you extended it so that it came out of the hood and faced forward so that you get the forced induction affect??? just curios it was something I thaught about last night. Thanks for you thaughts</TD></TR></TABLE>no, absolutely not...the area above your hood is a low pressure zone and will more likely rob power , how ever if you have the itbs opening near where ur windshield meets ur hood you will see gains
Old Dec 30, 2005 | 02:45 PM
AnToNy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whiskeydicks45 &raquo;</TD></TR><TR><TD CLASS="quote">Ok lets say I did have a K swap and it wasn't raining would there be any benefit from having the IDB's extend out so that it would give the forced induction effect??</TD></TR></TABLE>.
HAHAHA, you called them IDB's.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by temp &raquo;</TD></TR><TR><TD CLASS="quote">
hahaha i find it funny that only one person on here got what i was saying </TD></TR></TABLE>
temp's Avatar
Default Re: Question about ITB (z6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by z6 &raquo;</TD></TR><TR><TD CLASS="quote">no, absolutely not...the area above your hood is a low pressure zone and will more likely rob power , how ever if you have the itbs opening near where ur windshield meets ur hood you will see gains </TD></TR></TABLE>
werd. not only that but there are reasons that this isnt done, for one, and for 2 the majority of the time what you see is someone runs heat duct to the front of the car, sometimes in front of the radiator, but usually you see it off to the side of the radiator (like where the foglights would go on a 90-91 CRX Si bumper)
Old Dec 30, 2005 | 02:46 PM
Default Re: (temp)
OMG HAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHA
this is not telling me what would probably happen this is being an A** but thats just MO.
So why does temp hide behind that label lets find out who he really is
Old Dec 30, 2005 | 02:47 PM
temp's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whiskeydicks45 &raquo;</TD></TR><TR><TD CLASS="quote">this is not telling me what would probably happen this is being an A** but thats just MO.
So why does temp hide behind that label lets find out who he really is </TD></TR></TABLE>
ah-wha?....
