JDM ZC Clutch out...what clutch to buy?
As the topic states, my friend needs to replace his clutch but does not know what to ask for at the auto parts store. Will he need to ask for a d series clutch? thanks..
first off, the clutch you need depends on the transmission you have - if you have 88 transmission, you need 88 Si clutch - if you have anything other than 88 transmission, then you need to know which flywheel you have - 88-89 flywheel, you need 89 Si clutch - 90-91 flywheel, you need 90-91 clutch - if you have 89-91 transmission and 88-89 flywheel, you can also replace the flywheel with 90-00 and use 90-91 clutch
well my set up is a z6 motor with a zc tranny...and i used a 92-95 clutch, flywheel and plate......and before that i had the zc on my a6 and was using the a6 combo..
I Have an STD
May 4, 2005 05:58 PM
Ronin Panda
15
May 11, 2003 05:05 PM
