how often are you replacing your oil pump?
I'm changing timing belt and water pump currently and am wondering if I should replace the oil pump as well... 91k miles on it (98 itr) - it's my gf's car...
Modified by Black R at 6:49 PM 12/30/2005
Didn't think it would have to be changed until the pressure started to drop or fail. But that might be a little late
If my caR makes it to 150,ooo miles I'll do it then or unless
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by walker111 »</TD></TR><TR><TD CLASS="quote">I'm at 106k and havent changed it. I've never changed it in any of my cars.</TD></TR></TABLE>
Yeah I'm at 103k. I've never heard of anyone changing one.
Waterpumps go bad due to corusion which just causes leakes right?
I doubt that would happen to an oil pump...
I replaced mine at 65k, but I also had the engine out...
If you are replacing the timing belt, it is a very convenient item to replace. Generally, oil pumps will not show signs of failure until it is too late, but Honda pumps are very reliable and you do not regularly see failed pumps. But that is why they call it "preventative maintenance".
Why replace when you can rebuild?
http://www.team-integra.net/fo...15789
I'm not sure if the pix will come back up
....but it's a good comparo and quite informative
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bbasso »</TD></TR><TR><TD CLASS="quote">Didn't think it would have to be changed until the pressure started to drop or fail. But that might be a little late
oil pressure won't tell the whole story, you shouldn't have to worry about it unless you're revving really high and alot, have aftermarket pulleys and possibly too of agressive clutch? - i'm not sure about the clutch part through. if gear was to shatter, you probably won't get enough time to just go by oil pressure.
but speaking of replacing engine parts, what about valvetrain components? i'm pretty sure with stock hp and average driving should manage a whole lot of miles, 150-250k? thats if everything goes smooth..
but what about cars pushing more hp and revving higher and i'm talking about with stock valvetrain components?
</TD></TR></TABLE>oil pressure won't tell the whole story, you shouldn't have to worry about it unless you're revving really high and alot, have aftermarket pulleys and possibly too of agressive clutch? - i'm not sure about the clutch part through. if gear was to shatter, you probably won't get enough time to just go by oil pressure.
I've seen brand new oil pumps break in a week or last forever. I treally depends on your setup. Having a proper harmonic balancer is key, insoect the crank pully for wear.
But, we are talking about the heart of your engine here. I say rebuild it while you have the chance and sleep easy.
amej8
Feb 23, 2011 10:10 AM
DOHC_C-REX
Jul 9, 2008 03:46 PM
arielb1
Jun 10, 2007 01:50 PM
