RED valve cover paint code.
Old Dec 30, 2005 | 08:52 AM
Root79's Avatar
Default RED valve cover paint code.
Any one know the color code of OEM red valve cover?
It's red/mat/texture powder coat.
The company which produce that kind of powder?
Old Jan 1, 2006 | 08:23 AM
Finland's Avatar
You have to use VHT wrinkle finish paint, they make a red that's close to OEM. There is no code from the dealer, Honda doesn't repaint valve covers, they'll just install a new cover if the old one is damaged.
There's a pretty steep learning curve in applying wrinkle finish paint, the key is to heat the object you are painting evenly and keep it warm while painting, there are plenty of write ups on this on HT, I'm sure you could find it.
Old Jan 1, 2006 | 01:40 PM
B18EG6's Avatar
Default Re: (Boondock Saint)
Has anyone had any experience with krylon wrinkle paint? I recently tried my hand at it but I think I made it too thick
Old Jan 1, 2006 | 03:34 PM
machine4321's Avatar
the vht is great stuff. the more you put on the more wrinkle you get .
i did my calipers for my accord in vht black, very very strong paint
Old Jan 1, 2006 | 04:10 PM
B18EG6's Avatar
Default Re: (machine4321)
what color is that above? Also is that the VHT wrinkle, or plain ol vht paint?
Old Jan 1, 2006 | 05:40 PM
RCautoworks's Avatar
Default Re: (B18EG6)
Good luck finding vht , at least around here but I would assume its nation wide. They have a huge problem with there nozzle/can getting clogged. I know all the stores discontinued caring them.
Old Jan 1, 2006 | 05:50 PM
B18EG6's Avatar
Default Re: (90blackcrx)
Someone reccommended buying it frmo summit
http://store.summitracing.com/...h.asp
Old Jan 1, 2006 | 05:52 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18EG6 &raquo;</TD></TR><TR><TD CLASS="quote">Someone reccommended buying it frmo summit
http://store.summitracing.com/...h.asp</TD></TR></TABLE>
Well unless the can design changed, the problem is still going to happen.
Old Jan 2, 2006 | 01:30 AM
Root79's Avatar
Anyone maybe know! Are WHT products for sale in Europe?
Old Jan 2, 2006 | 04:35 AM
thermal's Avatar
I used the VHT red wrinkle finish and worked like a charm. I did seveal coats. I bought it online but I can remember the website... google maybe?
Old Jan 2, 2006 | 04:41 AM
bruthaboost's Avatar
Default Re: RED valve cover paint code. (Root79)
Just a thought, but since it's aluminum you can always have it anodized and get whatever finish you want.
Old Jan 2, 2006 | 07:24 AM
Mullet_SyTy's Avatar
Default Re: (thermal)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thermal &raquo;</TD></TR><TR><TD CLASS="quote">
move that grounding strap over one bolt to the left.
Old Jan 2, 2006 | 10:39 AM
The ones I have done
https://honda-tech.com/zerothread?id=449279
Old Jan 2, 2006 | 10:41 AM
yea my nozzles clogg up all the time
i just keep a smale bowl of thinner or stripper near and i just drop the nozzel in it when it clogges and its all good .
its hard to find in canda to as the chemical in it isnot allowed to be shipped or some gay **** liek that
the calipers were done in wrinkle
Old Jan 2, 2006 | 10:46 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by machine4321 &raquo;</TD></TR><TR><TD CLASS="quote">yea my nozzles clogg up all the time
The only problem is, if you buy some and let it sit, the can becomes clogged inside and basically you have a solid can of vht wrinkle paint.
Old Jan 2, 2006 | 12:57 PM
*Boostwerks*'s Avatar
It's all about the powder coat man.
imo... Shiney &gt; Wrinkle
Old Jan 2, 2006 | 01:37 PM
Root79's Avatar
Default Re: (Bryson)
yeah, powder coating are good. Did at least 15 covers using powder coat. For my engines previous and for friends. Have good partnership with on local powder coating shops. Only problem, they won't get for me that Honda OEM red/mat paint. Only for me it's not reasonable to order some 200 kg of powder.
Have question! Before coat lay cover must sand blasted. The sand can get in any smalest gaps. And it's become dangerous for engine. There are plate in inner side of cover for gas recirculation. How did you guys cover against sand.
Very nice covers in pics!
Old Jan 3, 2006 | 04:39 AM
WHTZ's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bryson &raquo;</TD></TR><TR><TD CLASS="quote">It's all about the powder coat man.
imo... Shiney &gt; Wrinkle </TD></TR></TABLE>
I agree
Old Jan 3, 2006 | 10:49 PM
gsrious's Avatar
Default Re: (Root79)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Root79 &raquo;</TD></TR><TR><TD CLASS="quote">
Old Jan 3, 2006 | 10:59 PM
Mikizzle's Avatar
If you place the can in room temp area the paint inside shouldn't chunk up. also your suppose to turn the can upside down and spary till it sprays clear stuff to ensure the nozzle doesn't get clogged.
Old Jan 4, 2006 | 06:17 AM
PolyPill's Avatar
Default Re: (GrnTurtle)
I've read that if you use 2 different types of paint in layers it will wrinkle due to the un-even drying. Like spray on an enamel paint, wait 5 min then cover with an acrylic paint. I haven't had time to try it, so I don't know how well it works or if it even works at all, but if it does it means you aren't limited to the 2 or 3 wrinkle colors available.
Also, if you mix silicon with the paint it will give it a textured look. It isn't a wrinkle, but someone might like how it looks. I haven't done it to a valve cover.
**Edit**
The 2 different types of paint, you need to put the faster drying paint on the top.
Old Jan 5, 2006 | 03:31 PM
Furyof4's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by machine4321 &raquo;</TD></TR><TR><TD CLASS="quote">the vht is great stuff. the more you put on the more wrinkle you get .
Nice job on the caliper conversion. Ive been thinking of doing the exact same thing. Any info on the swap?
Sorry to hijack.
Edit: I searched and found your thread about it but i'd like to hear your impressions now that they've been on for a while.
Modified by Furyof4 at 7:51 PM 1/5/2006
Old Jan 5, 2006 | 05:12 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GrnTurtle &raquo;</TD></TR><TR><TD CLASS="quote">If you place the can in room temp area the paint inside shouldn't chunk up. also your suppose to turn the can upside down and spary till it sprays clear stuff to ensure the nozzle doesn't get clogged.</TD></TR></TABLE>
All the cans were never used, I bought them straight from the store and they already had problems. I tried two different stores, same result.
I also remember I bought about 8 red cans and they were all black inside.
Old Jan 6, 2006 | 09:04 PM
Demetri's Avatar
https://www.pendrypowdercoatin...e595b
I'm going to try it out. Got some sitting here. I'll post some pics if you wanna see.
Old Jan 7, 2006 | 11:48 AM
Demetri's Avatar
Default Re: RED valve cover paint code. (Demetri)
this one was done with a heat resistant powder in flat black.
not bad for a home job in an old kitchen oven! i know, it's not a honda...
