b16a2 transmission fluid
Old Dec 29, 2005 | 11:32 PM
Ruben19's Avatar
Default b16a2 transmission fluid
my transmission has 76k and i would like to replace the fluid.
i heard you can use 10w30 motor oil but not sure.
i would like to use syntec gear oil. and which weight should i use and how much should i use. i think this transmission only take 2 quarts. but im not sure.
so if i jump to syntec gear oil, it wount hurt the trans.
i was thinking 75-90
Old Dec 30, 2005 | 12:42 AM
shorto85's Avatar
I run 10w30 full synthetic in my tranny and haven't had any problems with it.
Most people on here will tell you to use the Honda MTF.
Old Dec 30, 2005 | 01:12 AM
fmrprojects's Avatar
Default Re: (shorto85)
Honda MTF
Old Dec 30, 2005 | 04:21 AM
DRAGLS's Avatar
Default Re: (fmrprojects)
Redline oil
Old Dec 30, 2005 | 05:57 AM
D-Rob's Avatar
Default Re: (DRAGLS)
Honda MTF, or GM SynchroMesh Friction Modified.
Old Dec 30, 2005 | 02:56 PM
rodimus's Avatar
Default Re: (D-Rob)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D-Rob &raquo;</TD></TR><TR><TD CLASS="quote">Honda MTF, or GM SynchroMesh Friction Modified. </TD></TR></TABLE>
Old Dec 30, 2005 | 10:01 PM
ejprimo's Avatar
Default Re: (EVOL)
Nissan MTF
Old Dec 31, 2005 | 04:15 PM
Brick Top's Avatar
honda MTF
Old Dec 31, 2005 | 04:55 PM
rodimus's Avatar
Default Re: (brick top)
actually, although i do like honda MTF, it is only to a certain point; every to every other scheduled engine oil change.
honda mtf sheers down in weight.
for example, out of the container it's equivelant to a 5w30 motor oil...but after about 5k miles, depending on driving style and conditions, it's more like a 5w20 motor oil.
i reallllly like gm syncromesh friction modified. worth the extra dollars that it costs.
i'm curions EJPRIMO, please share with us why you like nissan mtf. you are one of the people i consider "oil guru's" here on h-t, and i am curious to find out why you like nissan's tranny fluid.
jaidedeye
20
Feb 24, 2013 05:35 PM
honda-guy72
32
Sep 21, 2008 09:54 PM
1JDMDOMINICAN
Sep 23, 2005 12:38 PM
HavokB18
20
May 29, 2003 04:16 PM
-BlueGSR-
May 25, 2003 03:40 PM
