any diy itb dyno sheets? real gains?
I have searched and searched and couldnt find anything on hp numbers with diy itb setups. I am very curious because i have a set and i would like to know if anyone has seen some real numbers. If you have them please post your whp gains and a quick rundown of your setup. Really interested to see what people have done!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nick M »</TD></TR><TR><TD CLASS="quote">You might find a Unicorn first.</TD></TR></TABLE>
I got one FS in the h-t market place.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AllM0tadc2 »</TD></TR><TR><TD CLASS="quote">haha alright but seriously has anyone dyno'd these things or am i going to be the first...</TD></TR></TABLE>
im interested in them too, i just picked up a set of CBR 954 itbs and was planning on putting them on my LS-vtec build just for the hell of it and see what happens
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Used2beAb16 »</TD></TR><TR><TD CLASS="quote">how big r they?
they are from a 954 cbr, i believe they are about 42mm
Home made Turbo put some on a B16 and they made around 170 whp, the block was honed a little, they have a post on here about it, it was called the trailer park b16 or something, if i find the link i will post it
they also give you all the steps for building them
so sad, yet so true
so sad, yet so true
I tuned a ITR with ITBs. The graph is on my website in the dynos section.
http://www.j-k-tuning.com
PS, the dyno reads about 10 Hp lower than the one across the street ( just for the record)
I have a dyno pic laying around..Ill try to dig it up... Mid range is HUGE. Top end is very plentiful
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dibble »</TD></TR><TR><TD CLASS="quote">Most of the diy itb are off of sometime of motorcycle. Most of the time they aren't big enough and it hurts more then it helps. Most of the time.</TD></TR></TABLE>
That's a very uneducated guess.
Its not just about how much air you can move...its about the speed of the air coming in...Not to mention that a byproduct of the faster air pulse brings more air in withit, ITBs also create... Fawk this. I've explained this too many times. Go do some research before you make a post.
Most aftermarket ITB kits in Europe and Japan use 42mm itbs and some use 45 and others 48...ITBs.. and with CBR itbs as well as Suzuki units having a taper, it acts as a Venturi. Which you might have to search to find out what that is, too.
CBR 954RR is 46mm tapers to 42mm. I've built a couple of sets using this method: https://honda-tech.com/zerothread?id=1008048
Here's the setup on my car that rice4life made...here the link https://honda-tech.com/zerothread?id=947796 and you can find the dyno graphs at http://www.j-k-tuning.com/
