GSR IAB Wiring
Old Dec 29, 2005 | 10:17 PM
PurEvl's Avatar
Default GSR IAB Wiring
I know there are 2 wires. I was told one was for sensor signal and one was sensor power....is there no ground? Or are these the right labels for these wires.
I got the pinouts etc and know the wire color and stuff. But is it really just a sensor signal wire and sensor power wire? LMK ASAP THANKS
Old Dec 29, 2005 | 10:44 PM
SETI20's Avatar
Yeah you're probably right about that.
If I remember correct, I hooked 1 up to 12V and the other to a relevant switched output.
Old Dec 29, 2005 | 11:55 PM
PurEvl's Avatar
Default Re: (SETI20)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SETI20 &raquo;</TD></TR><TR><TD CLASS="quote">Yeah you're probably right about that.
If I remember correct, I hooked 1 up to 12V and the other to a relevant switched output.</TD></TR></TABLE>
Relevant switched output?&gt;? What does that mean?? The correct ECU pinout?
Old Dec 30, 2005 | 12:14 AM
SETI20's Avatar
Some people hook it up to the vtec output if their ECU does not support IAB.
I have mine wired up to an Apexi VAFC-2. A cheap vtec controller should work too.
Hell, you can get a cheap shiftlight off ebay for $35 and hook it up to that too.
Acc3l3ratoR
May 1, 2019 07:41 PM
HondaLove517
Nov 24, 2008 04:46 PM
CrxEDguY
Apr 28, 2005 09:46 AM
blueskiesfade609
Apr 16, 2004 10:32 AM
IVI
Mar 27, 2004 04:47 AM
