D Series Question
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -Red- »</TD></TR><TR><TD CLASS="quote">D-series... Forced Induction.
-Red</TD></TR></TABLE>
dont belive so........well is it a d15 block?
cuh if it was a d16z6 i would tell ya to go y8 head
d16a6 pistons
y7 knife edged crank
port polish the head
y8 intake manifold
y8 throttle body with a spacer
d16a6 pistons
y8 intake manifold
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG_UMYEA »</TD></TR><TR><TD CLASS="quote">yea well besides Forced Induction
also can i replace the d15b7 intake manifold with a d16z6 manifold or will i get errors?</TD></TR></TABLE>
You can put the entire d16z6 head on. You need a p28 ECU.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1993civicex »</TD></TR><TR><TD CLASS="quote">cuh if it was a d16z6 i would tell ya to go y8 head </TD></TR></TABLE>
Why would you tell him this?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimmyAtlantis »</TD></TR><TR><TD CLASS="quote">Why would you tell him this? </TD></TR></TABLE>
some people think the y8 head flows better...i dont think it's worth it the effort though really
and im one of these ppl i well for a fact the y8 intake mani is a better flow desighn i dont have a dyno but the ports on the y8 look bigger than the z6 im going just by looks not mesearments so dont flame me if im wrong
i was talking about the head...but really my feelings apply to the IM as well...if i was going to change it out, i'd just go with some aftermarket performance IM
i havent seen anyone get big numbers without turbo on the d series. even if you get a better head itll only really show after you turbo the bitch. it dont cost to much. ive heard of guys doing it for around 1 grand. if you got the patience to shop around.
turbo with a good tune on stock internals will get you 230whp.
From: Toronto, Ontario, Canada, North America,, Earth
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1993civicex »</TD></TR><TR><TD CLASS="quote">and im one of these ppl i well for a fact</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1993civicex »</TD></TR><TR><TD CLASS="quote">im going just by looks not mesearments so dont flame me if im wrong </TD></TR></TABLE>
Are you seriously retarded? God, some people really have to get out of CARS, and get their high school diploma.
alright, thanks yea cause im gunna try getting most power out of d series head cause i dont have money to do a engine swap. so i was just going to do the "mini me" then later on turbo it.. so the z6 head is better or its all based on who says what
well, in the long run, building a NA D will prolly coastmore than a B16 swap, but i walk EM1's with my D16 all the time. my setup is a D16Y8 with the following: Edelbrock PerformerX IM, ITR Throttle Body, DC 4-2-1 Header, AEM Intake, APEXi WS2, and Evasive Shifter. Soon to come will be a Crower stage 2 cam, valve springs, and retainers, omni power valves, and a port and polished head. If you have the time and money(really not that expensive), you could get some JE 10.5:1 pistons, or even better, OEM P29(D16A1) pistons, that will have your compression around 12.5:1 if i remember correctly(In a y8 that is)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Average Al »</TD></TR><TR><TD CLASS="quote">a6 block is probably the thoughest its got a gridle</TD></TR></TABLE>
most d-series have a girdle, so i wouldn't use that as a basis on which block to choose.
couldn't have said it better.
so which head is better the y8 or z6?
found this is forum:
D16Y8 1590 9.6:1 127hp@6600/107lb-ft@5500
D16Z6 1590 9.2:1 125hp@6600/106lb-ft@5200
so it looks like the y8 is better
but average al says:
z6 out flows y8 head
y8 im out flows z6 im
so would z6 head with the y8 intake manifold with ITR throttle body be the best setup
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohckiller »</TD></TR><TR><TD CLASS="quote">i havent seen anyone get big numbers without turbo on the d series. even if you get a better head itll only really show after you turbo the bitch. it dont cost to much. ive heard of guys doing it for around 1 grand. if you got the patience to shop around.
turbo with a good tune on stock internals will get you 230whp.</TD></TR></TABLE>
...or supercharger.
...or supercharger.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tru »</TD></TR><TR><TD CLASS="quote">well, in the long run, building a NA D will prolly coastmore than a B16 swap, but i walk EM1's with my D16 all the time. my setup is a D16Y8 with the following: Edelbrock PerformerX IM, ITR Throttle Body, DC 4-2-1 Header, AEM Intake, APEXi WS2, and Evasive Shifter. Soon to come will be a Crower stage 2 cam, valve springs, and retainers, omni power valves, and a port and polished head. If you have the time and money(really not that expensive), you could get some JE 10.5:1 pistons, or even better, OEM P29(D16A1) pistons, that will have your compression around 12.5:1 if i remember correctly(In a y8 that is)</TD></TR></TABLE>
Send to DPR, for stage 6 head rebuild
only way to get good power out of them is to boost them.
Otherwise just do a B series conversion. easy for me to say tho since there are loads of them in breakers in the UK,.....
diewnaylomoah
Sep 30, 2007 06:56 PM
Honda_Tengoku
Sep 9, 2004 03:26 PM
