1997 Honda Civic 4dr Sedan, 120k Stock, $3200 New York, Northern New Jersey
Old Dec 29, 2005 | 07:12 PM
s13_240sx_92's Avatar
Default 1997 Honda Civic 4dr Sedan, 120k Stock, $3200 New York, Northern New Jersey
1997 Honda Civic DX Sedan 4 door.
The car is basically stock.
5 Speed Manual, no grinds.
Shift **** is from an Acura TL.
Alpine CD player, Pioneer speakers front, Infinity speakers in rear.
Cold A/C, P/S.
OEM floor mats, Drivers side is worn.
Has an OEM Armrest.
Updated Cup Holder. The door of the older style cup holder broke. This is very common if you didn't know.
Has 20% tint all around I believe. The rear window will need to be re-done as its bubbling. It was a professional job so it looks good otherwise. If you aren't old skool then you can remove the tint.
The hood has peeling clear coat. Rock chips and the pressure washer lifted the clear off the paint.
https://honda-tech.com/zerothread?id=1347812
It runs good and has the following maintance performed within the last 10k miles.
Exedy OEM Replacement clutch, PP, TO, Pilot Bearing,
OEM Honda Timing belt, Water pump.
OEM Honda Front Brake Pads.
OEM Honda Antifreeze and MTL
Stock Cat-back exhaust
Car is located in Northern NJ but I frequent Albany NY.
$3200
PM or post any questions.
Old Jan 5, 2006 | 12:49 AM
Default Re: 1997 Honda Civic 4dr Sedan, 120k Stock, $3200 New York, Northern New Jersey (s13_240sx_92)
ttt
official_del-sol
Jun 7, 2019 03:07 AM
ricky21
Jul 3, 2012 06:15 AM
90dteg
May 10, 2011 02:17 PM
rgensemer
Audio / Security / Video
Dec 25, 2010 11:39 AM
s13_240sx_92
Jan 18, 2006 02:23 PM
