does anybody kno if 93 integra gsr trannys came lsd???
Old Dec 29, 2005 | 05:56 PM
EnVyMe718's Avatar
Default does anybody kno if 93 integra gsr trannys came lsd???
does anybody kno if da 93 integra grannys cam lsd???and how u can tell if a tranny is lsd??? cause ima buy dis tranny off sumbody and they said its lsd and if sumbody could help me be able to tell if its lsd i would appreciate it...
Old Dec 29, 2005 | 05:59 PM
1point7db2's Avatar
Default Re: does anybody kno if 93 integra gsr trannys came lsd??? (EnVyMe718)
I think if you look through the diff where the axles go there will be a rod going through the center if its a non-lsd, you should be able to see straight through if it is lsd, but thats just what I heard somebody please correct me if Im wrong.
Old Dec 29, 2005 | 06:01 PM
EnVyMe718's Avatar
thnx i appreciate it, i jus tryin not to get ripped off...actually im givin him a used set of ctr pistons, and frm wut i undastand if its a lsd tranny i can get like 450 for it... is dat rite or wrong???
Old Dec 29, 2005 | 06:27 PM
D Rex's Avatar
Default Re: (EnVyMe718)
Tranny code should be ys1 and be cable. May have lsd stamp on case also if factory Lsd. If you look through the axle hole you should not see a shaft in there if it's got the lsd. Worth more if no grinds.
Old Dec 29, 2005 | 06:36 PM
EnVyMe718's Avatar
it supposedly has no grinds is a mint tranny with a mint casing... how much do u think it would go for... and yes it is a cable tranny
Old Dec 29, 2005 | 06:56 PM
madhive's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EnVyMe718 &raquo;</TD></TR><TR><TD CLASS="quote">does anybody kno if da 93 integra grannys cam lsd???and how u can tell if a tranny is lsd??? cause ima buy dis tranny off sumbody and they said its lsd and if sumbody could help me be able to tell if its lsd i would appreciate it...</TD></TR></TABLE>
No they did not come with a stock lsd.
No honda in the USA ever came with an lsd stock except the Type R and the new civic si.
Old Dec 29, 2005 | 06:57 PM
EnVyMe718's Avatar
its a jdm tranny
Old Dec 29, 2005 | 07:00 PM
EnVyMe718's Avatar
i jus talked 2 da kid dat got it and he said he looked thru da axle hole and didnt see a shaft, dat he was able 2 see str8 thru with no shaft in da way...
Old Dec 29, 2005 | 07:01 PM
whiteef8's Avatar
yea like people are saying
LSD = Straight thru differential casing
Non-LSD = Bar running perpindicular when you look thru the hole thingy, lol
if it is lsd, let me know a price and i may take her off your hands
please pm me...
Old Dec 29, 2005 | 09:15 PM
hotboxedcrx's Avatar
Default Re: (whiteef8)
These guys are correct.
hondaZvic
Apr 24, 2006 12:27 PM
sambam27
Sep 7, 2003 04:28 PM
CRX A4
Apr 5, 2003 04:04 AM
Nextelbuddy
Mar 31, 2003 07:40 PM
hybridhatch90
Sep 22, 2002 12:19 PM
