skunk2 pro1 in b18c1
Old Dec 29, 2005 | 05:52 PM
WhoDoYouThink's Avatar
Default skunk2 pro1 in b18c1 clearance problems?
i am about to put them in, but before i do i have a couple questions.
is that amount of lift enough that i need to worry about piston to valve clearence on a slightly milled b18c1 w/ JDM ITR pistons? i am using oem headgasket so i have alil more room as well.
Do people actually get the valve reliefs cut bigger on OEM pistons? let me know.
anyone with some pro1 experiences please chime in asap. thnx
Old Dec 29, 2005 | 06:12 PM
Default Re: skunk2 pro1 in b18c1 clearance problems? (2000turbogsr)
ttt
Old Dec 29, 2005 | 07:11 PM
Tbone's Avatar
I have run them on a b18c1 with itr pistons, 2 layer head gasket and about .0012 total milling off the head and block.. . Vtec hits and the valves dont.. The gears are at +1 +1.
Old Dec 29, 2005 | 07:46 PM
ShawnR's Avatar
Default Re: skunk2 pro1 in b18c1 clearance problems? (Tbone)
sry to thread jack, but i have the same question, but i have an all stock gsr wiht std. itr's, and i was worndering if buddy IV's would touch the pistons?
Old Dec 30, 2005 | 10:22 AM
Default Re: skunk2 pro1 in b18c1 clearance problems? (97gsrcoupe)
Thanks Tbone, thats all i needed to know. BTW... how much WHP were you able to pull out of your setup?
b20_driven
Aug 29, 2008 10:53 AM
EG6 Poe
18
Jul 12, 2008 06:11 PM
00bluesi
Jun 17, 2003 09:04 PM
Spoon92
May 21, 2003 09:04 AM
TRuST
Jul 30, 2001 09:13 AM
