Dohc ZC Swap Underway, have some questions...
Old Dec 29, 2005 | 04:42 PM
The Destroyer's Avatar
Default Dohc ZC Swap Underway, have some questions...
I'm currently in the process of replacing the d16a6 that was in my awd civic wagon w/ a dohc jdm zc motor. I just got the a6 pulled today and the ZC will take its place tomorow.
I've heard of some people having trouble with the dizzy on the ZC, i think i recall something about some of the plugs not lining up properly? Any info on this? I'm using the obd0 dizzy.
Also, the wiring harness that was used w/ the a6 will work with the ZC, correct?
Anybody that has done this swap w/ an EE or EF please chime in with any problems or expierences.. thanks
Old Dec 29, 2005 | 05:34 PM
jlicrx's Avatar
Default Re: Dohc ZC Swap Underway, have some questions... (Vtaaak y0)
the wagon a6 is the same as the Si - use the A6 harness - if your car happens to be 88 model, the ZC harness that comes on the engine will plug right in, if it is all there
Old Dec 29, 2005 | 06:02 PM
Default Re: Dohc ZC Swap Underway, have some questions... (jlicrx)
i only have the a6 wiring harness, the zc i purchase didnt come w/ one.
will i need to replace the connectors as that outline you posted said? sorry im a bit fuzzy on what i need to do or need to purchase. I was under the impression at first that everything would "plug and play" with the a6 harness and zc dizzy. thanks alot for any help, i appreciate it.
Old Dec 29, 2005 | 06:07 PM
jlicrx's Avatar
yes, you need to get a different connector as noted in the instructions - it is not plug and play
Old Dec 29, 2005 | 07:57 PM
Damn it.
Old Dec 29, 2005 | 10:00 PM
celestialcivic91's Avatar
the plug that you need for the ZC dizzy can be had from any 88-91 civic std,cx or dx engine harness
shouldn't be too hard to find one around a local yard or even order one from honda
Old Dec 29, 2005 | 10:14 PM
julio_bOostamante's Avatar
I'm a Jackass
Default Re: Dohc ZC Swap Underway, have some questions... (celestialcivic91)
yeah the SI plug is round but you can de pin it fairly easy and run the square plug found on any DPFi civics. its easy just match up the colors. 2 of the white wires will be the only boo boo you might run into. but if your car doesnt start then switch them around and it should fire right up. the blu/green & blu/yellow will have to be ran to the CAS on the exhaust side of the cam. use a 88-89 teg plug for that. again the jukyard is your freind
dizzy is from a 88-89 integra
good luck
Old Dec 30, 2005 | 03:28 AM
VegaS10's Avatar
I'm in the same boat, so, what you all are saying is that all you have to do it color match the wires and move the 2 extra wires to the crank angle sensor? If so, that's ******* sweet...
Old Dec 30, 2005 | 03:40 AM
I'm a Jackass
Default Re: (VegaS10)
yes that is all. color match everything
Old Dec 30, 2005 | 01:33 PM
Default Re: (julio_bOostamante)
Would swapping the "guts" from the a6 dizzy on to the zc bypass these problems? just looking at my options before i go spending some more $$. thanks
Old Dec 30, 2005 | 02:00 PM
jlicrx's Avatar
Default Re: (Vtaaak y0)
you have A6 distributor, correct? remove the round 7-wire connector from it and install it on the ZC distributor and run the 2 extra wires to the CPS
Old Dec 30, 2005 | 02:22 PM
Default Re: (jlicrx)
Alright, awesome thanks for all the help guys ill let you know tomorow how it works out
Redemption
Sep 25, 2009 09:48 AM
frenchycivic
Jan 11, 2008 03:30 AM
90b20b4
Jun 27, 2005 02:43 PM
SC-MK1
May 22, 2005 08:51 PM
