Jackstand placement? on a 99 civic coupe, exhaust q's
Old Dec 29, 2005 | 03:42 PM
mulletov's Avatar
Default Jackstand placement? on a 99 civic coupe, exhaust q's
Hi all
I need to lift my car up this weekend to remove my aftermarket catback and put the oem one back on. 99 Civic coupe. I have 1 jack and 2 jackstands. What would be the best placement for the stands so that I don't get crushed to death? Any tips for removing the B pipe from the cat? I know theres a nut and bolt tucked up high close to the body and I'm not sure how i'm gonna get to it. Does the OEM catback use any gaskets or anything? My car came with an aftermarket exhaust so this is all new to me.
I was planning to put the 2 jackstands on the passenger side jack points but I'm not sure how to get em there if I'll be using the jack to raise up one of the jack points?
Old Dec 29, 2005 | 03:47 PM
Buzzbomb's Avatar
Default Re: Jackstand placement? on a 99 civic coupe, exhaust q's (mulletov)
When I want to do this, I put the jack under the chasis where the supension connects. If your car is really lowered and you can't the the jack that far under, try using the front or rear lift points.
Old Dec 31, 2005 | 06:07 AM
99blusi's Avatar
Default Re: Jackstand placement? on a 99 civic coupe, exhaust q's (Buzzbomb)
One stand under each of the front lca connecting points(where they bolt to the frame). Jack on the rear tow hook. Remove the cat with the b pipe. Makes it alot easier. The cat bolts might be rusted on there. If they are, you can just cut the bolts and hammer out the part of the bolt that is pressed into the cat. Replace with normal bolts.
Old Dec 31, 2005 | 05:01 PM
mulletov's Avatar
Thx for tips everyone. Wasn't too hard at all.
looks and sounds great. Deep and loud. spoon n1 on EX oem b pipe.
Old Dec 31, 2005 | 05:04 PM
Tippyman's Avatar
Looks nice as hell
Old Dec 31, 2005 | 05:16 PM
civicEXtreme's Avatar
is that hitting the bumper? Is it making any loud banging sound? I had that problem on my old car, but thats overwith, heh.
Old Dec 31, 2005 | 05:52 PM
mulletov's Avatar
Default Re: (Tippyman98)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tippyman98 &raquo;</TD></TR><TR><TD CLASS="quote">Looks nice as hell</TD></TR></TABLE>
thx a lot.
No it's not hitting the bumper or clanging around. I have a very small space between the bumper and the tip. We'll see what happens once i try to mount a lip on there.
Old Dec 31, 2005 | 05:55 PM
Default Re: (mulletov)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mulletov &raquo;</TD></TR><TR><TD CLASS="quote">thx a lot.
No it's not hitting the bumper or clanging around. I have a very small space between the bumper and the tip. We'll see what happens once i try to mount a lip on there.</TD></TR></TABLE>
OH god, I could only imagine the headache thats going to cause, with the lip.
Old Dec 31, 2005 | 05:56 PM
dohcVTECeg2's Avatar
looks good
Old Dec 31, 2005 | 10:09 PM
alwaysoverkill's Avatar
for the future, there is a jacking point at the front of the car slightly towards the drivers side, jack there and then put the jackstands under the chassis jack points.
oh, and if its too low, drive up onto a small piece of 2x4 and that will give you another inch or inch and a half
Old Dec 31, 2005 | 11:01 PM
civic_eh's Avatar
nice exhaust
vroomvroomjdm24
Jan 16, 2016 01:42 PM
HondaKid99
May 27, 2009 09:26 PM
blackEKcoupe
Jun 12, 2007 08:17 AM
bunks99si
Feb 2, 2006 09:12 PM
