help factory deck removal
Old Dec 29, 2005 | 03:38 PM
96tegls's Avatar
Default help factory deck removal
i need help with removing factory radio. if anyone has a diagram or anything it would be helpful.
Old Dec 29, 2005 | 04:01 PM
96tegls's Avatar
anyone?
Old Dec 29, 2005 | 04:02 PM
2ndName's Avatar
You have to work up all the way from the arm rest, shifter, and then the center console.
The arm rest is held by 2 screws towards the back.
Then there should be a clip in the middle where you can place your cell phone and etc. that you snap off to reveal 2 more screws.
Then the shifter, I believe there are two screws towards the leg area.
Then you take everything in the center console out, like the ashtray and anything that can come out.
Then there are 2 screws on the bottom of the center console. And 2 more in where slot near the ashtray was.
Pull the middle part slowly because there are two clips that can get lost.
Should reveal most of what you need to get to the radio.
There is a guide on Team Integra, but they are down at the moment.
Old Dec 29, 2005 | 04:09 PM
caliteg96's Avatar
Default Re: (96tegls)
its screwed in... back behind (anti-theft)... i dont have diagrams but u gotta get the plastic around off so u can get under the radio. I think.... this would be the process.... I dont know if u have to take all the center console stuff out to do this... im pretty sure u dont. Start by taking out the ashtray... undo the 2 screws behind then pull all that out.. then undo the two screws that xpose... then two screws back farther on the sides.. near your feet... i think that u can then get under there... .not completely sure.
Hope this helps. If only team-integra.net wasnt down im sure there would be an article there. or maybe u can search and find one here.
-edit- OKAYYYYY Some one beat me to it
DustinFinn
Honda Civic (2001 - 2005)
Jan 21, 2008 06:30 PM
DsevenEm2
Jan 6, 2008 02:22 PM
TypeAhhh
Nov 18, 2005 06:23 PM
HaadkoeVTEC
Aug 17, 2002 05:56 PM
acatak
May 28, 2002 09:19 PM
