I need transmission help!! Please!!
Old Dec 29, 2005 | 03:36 PM
imnotted's Avatar
Default I need transmission help!! Please!!
Ok, I bought an S4C off of ebay. It had 3rd & 5th problems. I tear it apart and find the 3-4 sleeve set is the cause. I order a new one. I get it, it doesn't fit. The clusters I have in that transmission do not match the VIN attached to it. I need help identifying what transmission this sleeve set is from so I can order a new one. Below I've included pics & measurements of the 3-4 sleeve set. Please let me know ASAP! I have to have this car done in 12 days, which means I need it ordered in about 6! I'm sure I can think up a reward for the person that ACCURATELY figures it out (if you don't know, please don't guess).
Outer Sleeve
Teeth - 33
OD - 83mm
Fork ID - 75mm
ID - 70mm
Height - 18mm
Inner Gap Height - 9mm
Inner Sleeve
Outer Teeth - 27
Inner Teeth - 34
ID - 35mm
Synchro
Teeth - 27
ID - 54mm
OD - 65mm
Old Dec 29, 2005 | 03:53 PM
ludedeg's Avatar
Default Re: I need transmission help!! Please!! (imnotted)
it doesnt matter whitch one you order all b series hydro transmissions have the same hub and sleeve for third exvept the ls its smaller. Order the one from honda that the tsb was put out for it comes with carbon syncros.
Modified by ludedeg at 1:51 PM 1/2/2006
Old Dec 29, 2005 | 03:56 PM
ludedeg's Avatar
ohh i didnt read your post very well. I'll go to the garage and measure the ones I have. But if its a b series it should not matter. I have used the one for the 99 si on everything from GSR to type r ans have personally done so. I'm wondering if its not a b series but something else.
Modified by ludedeg at 1:49 PM 1/2/2006
Old Dec 29, 2005 | 04:07 PM
ludedeg's Avatar
not matching anything 3/4th related i have thats for a b series. the one you have is alot smaller.
Old Dec 29, 2005 | 04:43 PM
imnotted's Avatar
Default Re: (ludedeg)
Yea, I know. I don't know what it's from. I was thinking maybe an older integra, d series or f/h series.
Old Dec 30, 2005 | 05:44 AM
ludedeg's Avatar
I'll measure the b series cable stuff I have tonight. I don't have any D series stuff so possibly someone else will be able to measure that for you.
s373n7s373n
Jun 21, 2009 10:18 AM
96Civic_Coupe
Jun 7, 2008 11:34 AM
