GSR valve springs w/ ITR cams?
Old Mar 18, 2002 | 04:34 PM
bhcvc's Avatar
Default GSR valve springs w/ ITR cams?
Can GSR valve springs handle ITR cams up to the stock 8k redline? Basically wondering if the stock GSR valvetrain can handle ITR cams just being dropped in. Thanks.
Old Mar 18, 2002 | 04:52 PM
StinkyTofu's Avatar
Default Re: GSR valve springs w/ ITR cams? (bhcvc)
As long as you keep your stock redline you will be ok.
Old Mar 18, 2002 | 05:03 PM
bhcvc's Avatar
Default Re: GSR valve springs w/ ITR cams? (StinkyTofu)
kewl thanks!
Old Mar 19, 2002 | 09:13 PM
b19coupe's Avatar
I ran GSR valve springs with ITR cams. I had a retainer split and dropped an intake valve into #3 cylinder. It was not pretty. I don't know if it was due to the different lift of the ITR cams, or if it was because I was going to 9,000 rpm's on a regular basis. What I do know is that I won't do that again. You might want to consider upgrading to type-r springs.You only need the intakes; your GSR intakes are type-r exhaust springs. They are cheaper than a new motor.FYI.
Old Mar 19, 2002 | 09:15 PM
StinkyTofu's Avatar
Default Re: GSR valve springs w/ ITR cams? (b19coupe)
You revved to 9000 rpm on a regular basis on stock gsr valvetrain? Holy....
Old Mar 19, 2002 | 09:17 PM
b19coupe's Avatar
Yeah....I know....now
94VTEC2TONE
21
Mar 27, 2009 08:49 AM
Formula
Mar 16, 2006 08:06 PM
GSRintegra_Bob
Oct 16, 2005 02:30 PM
GSR -97
Nov 26, 2001 09:25 AM
