Wiring question...
I'm taking everything from my busted 98 coupe and putting it into a 00 hatch shell. All of the wiring in my hatch is still intact, so I'm going to re-wire the rear coupe harness to the hatch, here are the wire's coming out of the hatch:
Red w/ Black stripe-License Plate lights
Blue w/ Black stripe-Window de-foggers
Dark Green
Light Green -Windshield Wiper Motor
Light Green w/ Black
Black-Negative/Ground for all?
Dark Green w/ White-Upper Brake Light
= 7 wires total
So, in order to rewire my coupe harness, can I cut the plugs(which each have 2 or more wires atached, except the window de-foggers) off of it and color match?, resulting in 7 negative/ground(from the coupe harness) wires spliced into one(hatch black wire), or is there another way I should do this?
Trace the wires of each component down the wiring harness until it becomes one wire coming from the dash?
Can use whatever help i can get...
Modified by EJ7 at 12:51 PM 12/30/2005
Dark Green
= 7 wires total
Thanks, you just reminded me, the plug was cut, that was th reason for the wire descriptions^. I'm also not using the existing (i assume you mean coupe) harness because it isn't long enough. I would never be able to open the hatch.
Still looking for answers, the post at the top is hypothetical, I'm not about to go and butcher my harness, never done rewiring dealing with cut wires, Help please.
EFLander
May 26, 2010 03:50 PM
