what's the best way to....
Old Mar 18, 2002 | 04:20 PM
neumonik's Avatar
Default what's the best way to....
run a new wire? I have a short on the wire that connect from the vtec solenoid to the end of the harness.
I'm looking for clean and relatively simple. I was going to cut the wire (green/yellow) and solder a new one from end to end. Will that hold up in the engine compartment?
Thanks!
Frank
Old Mar 18, 2002 | 04:29 PM
EP3_05's Avatar
Default Re: what's the best way to.... (neumonik)
It should be fine as long as the connections are good. I had to extend some wires when I swapped and I just soldered on some more wire and then neatly taped over the connections. They haven't caused me any problems since I did them.
Old Mar 18, 2002 | 05:08 PM
rainforest's Avatar
Default Re: what's the best way to.... (91civic)
put it through through the firewall where the ac lines go...and solder and use heat srink insulated wire.
Old Mar 19, 2002 | 02:21 AM
neumonik's Avatar
Default Re: what's the best way to.... (rainforest)
awsome... thanks!!
fcm
Aug 30, 2013 03:30 AM
datEM2
Honda Civic (2001 - 2005)
Apr 18, 2008 03:26 PM
YoungKadafi
Audio / Security / Video
Apr 16, 2007 06:53 PM
D16Z6racing
Mar 21, 2007 05:56 AM
92_honda_hatch
Sep 28, 2006 09:06 PM
