FS: B16 cams, valve springs, and retainers - parting out B16 head
Old Dec 29, 2005 | 08:30 AM
BlueTeg's Avatar
Default FS: B16 cams, valve springs, and retainers - parting out B16 head
B16 intake and exhaust valve springs....$15 (only $10 if you purchase another item)
All 16 retainers for the B16 head.....$10 (only $5 if you purchase another item)
Other misc items I am parting out from the head:
VTEC solenoid. Read here to see if you're interested in buying it: https://honda-tech.com/zerothread?id=1476588
Asking $20
Timing belt cover (outside). The one that goes right under the valve cover on the "outside". The bottom of the cover has been shaved 1/2" with my dremel for better fitment. Asking $10
B18c head bolts. Used and torqued down once. Asking $10
B18b/B20 head bolts. Used and toqued down once. Asking $10
Buy with confidence; my vouch thread: http://hondamarketplace.com/zerothread?id=993363
SOLD....
B16 intake and exhaust cams.....$30 **SOLD**
B16a head bolts. Used. $8 **SOLD**
Sensor on the passenger side of the head that has a normal looking white plug with small pins inside....$5 **SOLD**
Sensor on the passenger side of the head that looks like a headphone jack....$5 **SOLD**
Complete set of rocker arms and shafts for the intake and exhaust side....$50 **SOLD**
B16 cam holders and plates, complete set. **SOLD**
4 of the "half size" caps that go at all 4 corners of the head + the 3 long ones that go in the middle + the 2 camshaft holder plates (that run the width of the head, one on the exhaust side, the other on the intake side) that go on top.
B16 cam holder/plate mounting hardware. **SOLD**
There is a total of 20 bolts/studs with a 12mm head needed to fasten the holders/plates down. 4 of those 20 are the "long" valve cover studs. The long valve cover studs are sold. I have the remaining 16 bolts needed.
There is a total of 8 bolts with a 10mm head needed to fasten the holders/plates down at the left and right edges of the head for intake and exhaust side. 6 of those 8 are identical in length and thread pitch. I have all 6. The remaining 2 out of the 8 are longer than the rest and are used to fasten the cam holder that is closest to the distributor. I only have one of the two "longer" 10mm bolts.
***Asking $40 for all of the holders/plates/mounting hardware.***
Modified by BlueTeg at 10:48 AM 1/7/2006
Old Dec 29, 2005 | 09:31 AM
BlueTeg's Avatar
Default Re: FS: B16 cams, valve springs, and retainers - parting out B16 head (BlueTeg)
Old Dec 29, 2005 | 09:34 AM
Baggy Spandex's Avatar
bump
Old Dec 29, 2005 | 12:56 PM
BlueTeg's Avatar
Default Re: FS: B16 cams, valve springs, and retainers - parting out B16 head (NAisBEST)
thanks dude....
Old Dec 29, 2005 | 08:00 PM
BlueTeg's Avatar
Old Dec 29, 2005 | 09:53 PM
BlueTeg's Avatar
All PM's replied to....
Old Dec 30, 2005 | 07:33 AM
BlueTeg's Avatar
Old Jan 2, 2006 | 10:30 AM
BlueTeg's Avatar
Sale pending on a few items. Couple other items added.
Old Jan 2, 2006 | 01:04 PM
BlueTeg's Avatar
fiesta bowl bump
Old Jan 2, 2006 | 03:18 PM
enigmaEG6's Avatar
2K6 bump
Old Jan 3, 2006 | 09:47 AM
BlueTeg's Avatar
Default Re: FS: B16 cams, valve springs, and retainers - parting out B16 head (enigmaEG6)
thanks dude.
Sugar bowl tonight....not sure if my liver is going to last until the rose bowl.
Old Jan 6, 2006 | 07:52 AM
BlueTeg's Avatar
The guy that put down the deposit on the items you see pending has until tomorrow until 2:00 p.m. to get the rest of the money to me, otherwise they're back up for grabs.
Old Jan 6, 2006 | 02:03 PM
BlueTeg's Avatar
still no sign of the guy that put the deposit down.
Old Jan 6, 2006 | 02:04 PM
todapowered's Avatar
Old Jan 7, 2006 | 08:48 AM
BlueTeg's Avatar
List updated....bump
Old Jan 8, 2006 | 09:44 PM
RhdRicheeee's Avatar
az
Old Jan 12, 2006 | 01:08 PM
BlueTeg's Avatar
thanks dude
Old Jan 13, 2006 | 02:28 PM
BlueTeg's Avatar
Bump
Old Jan 14, 2006 | 12:29 PM
BlueTeg's Avatar
rump
Old Jan 18, 2006 | 08:02 AM
BlueTeg's Avatar
AM bump
Old Jan 19, 2006 | 08:04 AM
BlueTeg's Avatar
up up and away...
Old Jan 21, 2006 | 12:10 PM
BlueTeg's Avatar
lots of stuff left on this head.....
Old Jan 23, 2006 | 07:51 AM
BlueTeg's Avatar
ttt
boostek9
Aug 16, 2011 04:24 PM
tony_yang
Sep 21, 2010 03:31 PM
watisjdm
Jul 13, 2008 04:21 PM
BlueTeg
Southwest (Sales)
Jan 7, 2006 08:50 AM
